Dropmember ?
What is the recommended front wheel width and back spacing for trucks with a dropmember?
Re: Dropmember ?
An 8-8.5" wheel w/5".00 would work well.
Re: Dropmember ?
What diameter wheel and tire combo do you plan on running?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: Dropmember ?
I'm running 20x8.5" with 4.5" backspacing. works fine for me. no rubbing with 70lbs of air which is a little less than I use at ride height. Some guys go with a little more backspacing.
Re: Dropmember ?
I'm running a 20X8.5 with a 5.25BS in the Front.
Re: Dropmember ?
Re: Dropmember ?
how about a 265 35 22 on a 22 by 9 inch wheel? or may be a 305 40 22 which i could get a real sweet price on tires, on the 22 by 9's on a 90 burb
#8 | |
Re: Dropmember ?
![]() Join Date: Nov 2006
Re: Dropmember ?
can anyone tell me the track width with stock style a arms?
Re: Dropmember ?
What size tire would that be?
I think ill be at that size with some rubber band 24's so im most likely going with 22 in front to be safe |
Re: Dropmember ?
I recall seeing 64.5" front disc brake track width. Pre-71 trucks were 62" rear width; post-71 were 64-ish (wheel mounting surface to wheel mounting surface).
Re: Dropmember ?
#13 |
Re: Dropmember ?
That's stock track width..... DM track width would be 62" from memory.
