04-22-2010, 09:33 AM | #1 |
"Hooked on Quack"
A/C question
Yet another question in the line of trying to decide if I want to use used parts or spending the extra $$$ for new. Found a donor truck that had factory A/C. All the parts are there from controls to compressor. My truck is not an A/C so I don't have any of the vents and I don't know if those can be pulled.
The plus side is this system is 1/3 of the price a vintage air unit. I know I will need some parts but it seems like a solid system to start with. Anyone made this conversion of a stock A/C system into a non A/C truck? |
04-22-2010, 10:08 AM | #2 |
wanna be 67
Re: A/C question
change out your dash, cut along the dash pad holes, two bolts and replace with a/c dash. Now you have a a/c truck.
04-22-2010, 12:32 PM | #3 |
Re: A/C question
The firewall is different too.
I modded mine. It isn't impossible but you do need to weld in some metal and cut some other away. I purchased an AC dash intending to do like 19stepSide72 said but I eventually just used it for a template to cut holes in my current dash.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-22-2010, 05:53 PM | #4 |
Re: A/C question
Swap cabs
04-22-2010, 06:05 PM | #5 |
Re: A/C question
You can get louvers that mount under or through your dash.
see http://www.oldairproducts.com/catalo...0000_120132055
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
04-22-2010, 07:20 PM | #6 |
Re: A/C question
You don't HAVE to modify the firewall. I just set the box in place and drilled new holes. A/C and heat work just fine. Old air or Vintage air has the templates to cut new holes that you can print out.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
04-22-2010, 10:11 PM | #7 |
"Hooked on Quack"
Re: A/C question
awsome thanks!!
04-23-2010, 12:22 AM | #8 |
Old member
Re: A/C question
I did it the hard way I guess but the cheapest I guess to. I bought a junk AC truck and swaped it all over to my truck. I cut the holes and mounted everything myself.
http://my.att.net/p/s/community.dll?...eid=298462&ck=
