? for the baggers in here.
What size rims and tires do you have? Where did you set your track bar at(ride height, slammed, in between)? I have a 67 C10 stepside and I'm in need of new tires bad. I have 215/6515 on it and I have a new track bar coming. Please post your rim and tire size and let me know if you have any problems such as rubbing. I only need info on the back because i'm going to keep my front 215/65/15. Thanks.
Blaze-Air
Re: ? for the baggers in here.
Yea, set it at your predicted ride height. You may need to tweek it once you figure out what your ride height will be.
I run 8in rallys with 275/60/15 on rear. I have a 71-72 rear which is wider than the 67-70 rear. My tires are very close on the outside when aired down...You should be just fine since you have a narrow rear. |
Well, I actually have a 71 rear end. So I'll be in the same boat as you but 275 is what I wanted. What is the offset on your rims?
Blaze-Air
I think stock 8in rallys are 4.5in b/s...
![]() Join Date: Sep 2007
5 lug rallys actually have less of a backspace than the 6 lug rallys, thats why its a good tight fit when the truck is lowered.
1967custom |
