Inline 6 Intake / Exhaust Question
I posted this question on the engine page - thought I might get more input if I posted here as well . . .
I've got a '65 suburban with a 230 L6. I'm ignorant on these motors - I admit that up front. On an inline 6 (194/230/292) the intake and exhaust manifolds are bolted together. If I wanted to make an exhaust change (headers, etc.) without the expense of replacing intake and carb at the same time - is it possible? Can you run stock intake / aftermarket exhaust or vice-versa? If so, what would I need to do to make it work? Thanks for your help. I apologize up front for my lack of knowledge on all things L6. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Inline 6 Intake / Exhaust Question
Yes, all of the stock intakes are bolted together with three bolts. You can swap intakes and exhausts back and forth. Different brands of manifolds might require headers though.
#3 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I was thinking of this this myself! I was looking at these headers:
http://www.summitracing.com/parts/BIG-11510FLT/ |
Thanks for the link - I had been looking at Hedman headers form LMC. I like the price of Summit's better.
Now I've just got to decide if this old 6 cylinder is worth the effort. |
Thanks Aggie91 - that's just what i needed to know - whether or not it was possible.
Clifford Performance also offers 6 cylinder stuff.
http://www.cliffordperformance.net/M...gory_Code=C250 My Father used some of their stuff in his Jeep CJ7 many years ago.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Left Field ...Have you thought about putting in a HEI distrubitor in? I just did, BIG DIFFERENCES!!!
Six in a row makes it go...
![]() Join Date: Mar 2009
Clifford stuff:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#10 | |||
I bolted a set of Langdons cast iron headers on my 65 with a 230 a month ago. Next is an Offy single quad as soon as I come up with a carb. I was planning on a Holley 390 cfm but have decided to look for an older Rochester 4 jet which should bolt on without an adaptor plus look a little more period correct.
Life is too short to drive a boring vehicle. Last edited by hb32; 04-22-2010 at 08:21 PM. |
#12 | |
I went with the Pertronix and not sure if it is a major improvement but seems to run better.
Life is too short to drive a boring vehicle. |
#13 | |
I like those iron headers! They look slick! and so different ![]() |
#14 |
i'm gunna run those cast iron ones on my 292 from Langdon's, i've heard good things about his stuff. check out his site langdonsstovebolts.com and listen to the sound clip he has of his split manifold sixer, it sounds awesome!!
'66 c10ish straight 292 power! |
#15 |
Thanks for all the info - I knew I was coming to the right place.
hb32 - FYI - '68OrangeSunshine posted his set-up over on my post in the engine section. Here's what he did for a classic looking carb; "an Edelbrock 1404 500 CFM 4Bbl [clone of the Carter AFB] on an Offy intake and Clifford long tube headers." 11echo - I was considering HEI - good to hear from some folks who have already done it. thanks again everybody - this helps a great deal. It's nice to get some answers without having to take everything apart first. |
#16 |
Here is how it sounds
#17 |
![]() Join Date: May 2009
Hey Shaky what carb are you using on your Clifford? I used a Edelbrock 1404 manual chock and have been happy with it. Just a note if your going to lower your truck or bag it the long headers are not the best idea, with short headers you can run the pipes through the frame just something to think about...Vernski
#18 | |
#19 |
Here's what a stock intake and exhaust manifold look like. You can see that they're two pieces and that you can change out one or the other:
#20 |
Any issues with the carb north/south and how does it run with the 390?
#21 |
No north/south issues. It took awhile messing with jets and power valves and springs to get it working right since it was probably set-up for a V8 out of the box. It pulled strong when the secondaries opened up and it was up on the cam.
