02-09-2003, 05:08 PM | #1 |
Frame question...?
I've got an automatic in the 68 but the frame has the clutch pivot bracket riveted onto the frame by the left side exhaust manifold. Do all the frames come with these or was my truck originally a stick shift? It will probably get cut off as I don't need it.
Thanks for the help.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
02-09-2003, 05:14 PM | #2 |
Fabricate till you "puke"
the auto trucks didnt have the bracket for the clutch linkage, so yours must have been a stick at one time in its life.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
