Old 04-22-2010, 02:05 PM   #1
chillware
Power steering conversion hose routing pics?
Hey all.. Just curious if anyone has any pics of their power steering hose routing after converting from manual steering?? I just want to see what it's gonna look like under the hood..
Thanks a ton!
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 07-31-2011, 09:41 PM   #2
likaroc13
Rollin' Old Skool
Re: Power steering conversion hose routing pics?
anybody have pictures of the routing? doesn't look like much room for hoses to fit underneath the inner fender, & i'm wondering if I'll need to trim/cut...currently in the process of converting mine, so any help is greatly appreciated
Old 07-31-2011, 10:44 PM   #3
'63GENIII
'63GENIII's Avatar
Sorry no pics but my fender was slightly bent up to just clear the hoses. I've often thought about trimming the inner fender but Ive just never had to. Seems to work fine with the bend. Doesnt look bad either
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-31-2011, 10:53 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
I put a 1/2 inch x 1 inch notch in my inner fender at the frame.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-01-2011, 09:08 AM   #5
wildearp
wildearp's Avatar
The hoses on mine have several inches of steel tubing at the ends on the steering box. These easily route under the fender well and have plenty of room.
I don't have a photo available.
wildearp is offline   Reply With Quote
Old 08-02-2011, 10:36 PM   #6
dthela
dthela's Avatar
originals had oval cutout in inner fender with a clamp that screwed to the inner fender
dthela is offline   Reply With Quote
Old 08-03-2011, 12:27 AM   #7
OneCoWBoY1992
i drilled 2 holes using a hole saw in the inner fender to have the right angle on the hose to steering box
OneCoWBoY1992 is offline   Reply With Quote
Old 08-03-2011, 06:21 PM   #8
towersddg9
towersddg9's Avatar
Here is what i did, Im trying to keep from cutting the inner fender, I used the braided hose I was able to route thru an existing oblong hole in the frame, once thru the hole i attached fitting, looks like it will work and clear the fender
towersddg9 is offline   Reply With Quote
