Old 04-22-2010, 04:06 PM   #1
Matt_ks
Matt_ks's Avatar
Lowering My 96
So i just got a 96 chev, 1/2 ton 2wd standard cab and im wanting to drop it a bit.. im thinking somewhere in the neighborhood of 4/6.. can anyone tell me the best and easiest kit to buy!!
Matt_ks is offline   Reply With Quote
Old 04-22-2010, 04:12 PM   #2
NORCAL SS
Re: Lowering My 96
ill get better ones this weekend. Going for alignment after work then lower the rear 1 inch tonight
ive been doing kits on these trucks since 93 and sell both belltech and djm. I would go with the djm 4/6 and I beat anyones prices shipped. I know Mike at djm for years now.
2011 CTS-V MODDED
2006 TRAILBLAZER SS TVS2300 BLOWER SOLD
2007 TRAILBLAZER SS 11.7@117 1.817 60' Wifes Daily
NORCAL SS is offline   Reply With Quote
Old 04-22-2010, 04:40 PM   #3
JWall
Frequent Flyer
JWall's Avatar
Re: Lowering My 96
I generally use BellTech or Western Chasis but have used DJM in the past also.
My daily is 5/7 dropped with all Western Chasis & I'm very pleased.
The notch with the Western flip kit seems to be larger because it doesnt bottom out as often as other trucks I've had with the BellTech notch.
- Justin
1 Owner 1976 SWB
Old 04-22-2010, 04:47 PM   #4
1badgmc
1badgmc's Avatar
Re: Lowering My 96
DJM, Western Chassis, BellTech or McGaughy's and you can't go wrong.
Personally, I would avoid BellTech spindles because they push your front wheels out slightly and might give clearance issues with some wheel/tire combos, but if that's no concern for you, then no worries.
Old 04-22-2010, 06:19 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Lowering My 96
This link is in another post.....It is recommended reading if you want to know what to do.
http://docs.belltech.com/66056607-888.pdf
Member Nr. 2770
Old 04-22-2010, 07:38 PM   #6
Matt_ks
Matt_ks's Avatar
Re: Lowering My 96
NorCal.. tell me roughly what a complete kit including shocks would cost me.. that would be great..
Old 04-22-2010, 10:16 PM   #7
og350
og350's Avatar
Re: Lowering My 96
Hey jwall what all did you use in the fron for your drop? what size tires are you running?
og350 is offline   Reply With Quote
Old 04-23-2010, 12:02 AM   #8
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: Lowering My 96
Matt, welcome to this side of the board! And now, because somebody has to do it...
Old 04-23-2010, 12:35 AM   #9
NORCAL SS
Re: Lowering My 96
the belltech is a few hundred more i just need to know if you want to go with spindles/springs or a arms and springs
2011 CTS-V MODDED
Old 04-23-2010, 07:49 AM   #10
JWall
Frequent Flyer
JWall's Avatar
Re: Lowering My 96
2" Spindles & 3" Springs in front
255/60/15 front & 275/60/15 rear
- Justin
1 Owner 1976 SWB
Old 04-23-2010, 03:46 PM   #11
Matt_ks
Matt_ks's Avatar
Re: Lowering My 96
spindles and springs... !!
Old 04-23-2010, 11:18 PM   #12
Blitz
Mr. Thread Killer
Re: Lowering My 96
Which combo provides the best ride/comfort for the 4/6 & 5/7 drop?
Matt, what size wheels will you be running, 20's?
Blitz is offline   Reply With Quote
Old 04-23-2010, 11:35 PM   #13
Matt_ks
Matt_ks's Avatar
Re: Lowering My 96
Blitz.. i will prolly be running the stock wheels for a while.. i have a set of 17s i might put on it..
Old 04-24-2010, 09:14 AM   #14
1badgmc
1badgmc's Avatar
Re: Lowering My 96
Whether you're doing 4/6 or 5/7, your basics are going to pretty much be the same.
For the rear, you'll have a flip kit for 6" and then you'll add a pair of shackles in the 1" hole to the flip kit to get your 7".
In the front, 2" spindles and springs. 2" springs for a 4" drop or 3" springs for a 5" drop. DJM makes 2" and 3" lower control arms, but DJM doesn't recommend using them with drop springs. I have seen some serious balljoint issues from people who do use them with springs.
Old 04-24-2010, 11:41 AM   #15
Blitz
Mr. Thread Killer
Re: Lowering My 96
Ok. So sounds like either/or but not both in this case. Either drop spindles/drop springs/stock control arms OR drop spindles/stock springs/drop lower control arms.
Old 04-24-2010, 09:59 PM   #16
1badgmc
1badgmc's Avatar
Re: Lowering My 96
I will also add that you CANNOT use the drop control arms with drop spindles. This combination will have your spring pocket hanging so low that you'll be popping the reflectors on the street.
Old 04-24-2010, 10:01 PM   #17
Blitz
Mr. Thread Killer
Re: Lowering My 96
Noted.
Old 04-25-2010, 07:33 PM   #18
fiddy9apache
fiddy9apache's Avatar
Re: Lowering My 96
yeap very true, drop control arms are the way to go. if you want to be cheap about it you can get a set of 3/4ton coil springs and cut them. i ran a cut set with my drop control arms and liked it. the truck felt more stable in the corners along with the sway bar.
fiddy9apache is offline   Reply With Quote
Old 04-25-2010, 08:53 PM   #19
og350
og350's Avatar
Re: Lowering My 96
How many coils did you cut off?
Old 04-25-2010, 10:17 PM   #20
fiddy9apache
Re: Lowering My 96
im thinking i cut half a coil, but its been awhile.
Old 04-25-2010, 11:07 PM   #21
og350
og350's Avatar
Re: Lowering My 96
what do you guys thik about cutting one coil off a half ton spring. i did it once on another car i had and it rode really bad! i guess if it doen't work ill just get drop springs and stock control arms.
Old 04-25-2010, 11:16 PM   #22
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
Re: Lowering My 96
hey peeling reflectors off the high way is fun, well until mr policeman sees you doing it an figures out your the one responsible for most of the missing reflectors,,lol........i have cut coils for a lincoln i had one time, rode pretty good... was gettign ready to cut the coils on my van until i ran into a super deal at wal mart for 2 tires, they were 15's like i needed, but to big to do a drop now, oh well next spring..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
