Old 04-22-2010, 06:14 PM   #1
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
a/c questions
on my 75' 1/2 ton big block,
blower motor was only working on HI
i replaced the blower resistor, then found out my ac relay on the ac box was bad. (relay working now)
the blower fan speeds work correctly in all ranges (bi-level, defrost, heater, vent etc)
when i have the selector in MAX AC, the blower motor only works on HI speed...
is this normal?
I thought the speed would have been adjustable...
Input please....
tommie is offline   Reply With Quote
Old 04-23-2010, 08:45 AM   #2
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: a/c questions
anyone with factory ac?
Old 04-23-2010, 12:49 PM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: a/c questions
anyone with an a/c wiring diagram for a 75?
Old 04-23-2010, 06:22 PM   #4
raws67
raws67's Avatar
Re: a/c questions
Max a/c just routes air from inside cab and not outside, basically recirculating cab air that is already cooled. Hi speed will be the same either a/c or max a/c. Is it only on max a/c that you cant get med or low fan?
raws67 is offline   Reply With Quote
Old 04-23-2010, 07:24 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: a/c questions
yes, only on max ac...
on max ac i only have hi speed...
on all other settings, i have all blower speeds....
never ran into this problem before...
Old 04-24-2010, 02:25 AM   #6
raws67
raws67's Avatar
Re: a/c questions
As far as I know there should be no interconnection between the two since vacum control is the only change when going to max a/c. I will check my service manuals in the am and try and get you a diagram of the wiring.
Old 04-24-2010, 03:07 PM   #7
raws67
raws67's Avatar
Re: a/c questions
These are from my 74 gmc service manual. Let me know if you need any closer pics. Good luck
Old 04-24-2010, 10:11 PM   #8
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: a/c questions
thanks for the info... now i have to read it all!!!!!
