Old 04-22-2010, 09:01 PM   #1
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
serious CARB question.
My truck ran great, so what do i do? I adjust the HEI,adjust the jets (mixture) and now when i get to 3rd gear it bogs out and dies.
It seems like it's flooding, so i replaced it with another q jet (they are both q jets) and the SAME thing! It bogs out and dies when it reaches third.
Got me pullin my hair out trying to figure it out.
I also noticed the wire to the HEI (Bat.) connector is just jammed in there, no proper connector.
any suggestions?
p. s . Its got an aftermarket (small) fuel filter in the fuel line from fuel pump to carb..
beebster is offline   Reply With Quote
Old 04-22-2010, 09:09 PM   #2
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: serious CARB question.
If your are having the same problem with two different Carbs, then you can almost count the Carb itself out. Dose your Q-Jet have an electric choke? Other then 3rd gear dose it seem to be running good? Do you have a fuel pressure regulator? Last one, how old is your fuel pump?
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 04-22-2010, 09:17 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
I'd investigate the possibility of a vacuum leak.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-22-2010, 09:21 PM   #4
handsomerob
handsomerob's Avatar
As soon as it quits hop out and pull a plug and see what the plug tells ya, rich or lean . . . I'd start there myself.
handsomerob is offline   Reply With Quote
Old 04-22-2010, 10:08 PM   #5
beebster
beebster's Avatar
actually they both ran fine for a few days when first installed, then it seems like they started flooding. I did change the original (rubber) fuel line this spring. I probably put i bigger diameter line, i'm pretty sure.
I'll install a fuel pressure regulator or just buy fuel line tomorrow.
I checked for vacuum leaks and got nothing, i ran it both lean and rich when each q jet was installed until i had em running right, then a couple days later. bogging (flooding i think) always in third.
also noticed when i turned off the truck, it would stay on and stumble and extra 2 seconds.
Old 04-23-2010, 09:34 PM   #6
gonzo6869
gonzo6869's Avatar
Like I said before, I doubt that it is your carb, but have you checked the float levels lately. It’s weird that it only happens when you are in third, next time it happen, like said, check one of your plugs, also, take off the air cleaner and check the carb to see if it is still dumping fuel. Next suggestion is, do you still have the old parts from before your upgrades, if you do, you might want to try putting it back together the way it was before and see if your problem goes away.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 04-23-2010, 09:41 PM   #7
gonzo6869
gonzo6869's Avatar
If you do buy a pressure regulator, go for the cheapest one for now. That way if it doesn't solve the problem, you’re not out much $$. If it fixes it, you can continue to use it, but plan on getting a good one eventually, they run about $75-$100 on up, a cheap one is in the 20's.
A smaller fuel line will not solve a pressure problem, or at least I don’t think it will.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 04-23-2010, 10:01 PM   #8
hilandr452
hilandr452's Avatar
Usually when it runs a few seconds after you shut it off, or "diesels", that's an indicator of bad timing. Have you checked the timing?
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 04-24-2010, 12:04 AM   #9
Tkmadone
I would definitely change out the fuel filter if you haven't already.
Tkmadone is offline   Reply With Quote
Old 04-24-2010, 03:12 AM   #10
beebster
beebster's Avatar
Ok now this is strange.
I removed the carb to look inside it, and as i said it's from a 79 corvette.
well, i cleaned it up and put it back on. then i noticed when i tried to start the truck my "pink" wire behind the distributor would catch on fire. Until it finally burned in two.
Well, it's obvious the distributor was wired in bad (as i said in previous post a wire going to "bat" was just shoved up there)
so per instruction on "hei" thread, I removed old "bat" wire and also the wire that ran to the starter.Then ran a 12 volt inline fused wire from "ign unfused" to "bat" and lo and behold problem gone.
truck now runs perfect again.
It seems all this carburator bogging was somehow due to the connection to the distributor.
If someone can explain this "lack" of power or dying in "third gear" because of the bad disributor wiring i'd love to hear it.
highlander452: yes, it was the timing keeping it on an extra 2 seconds, i adjusted and bam! problem gone.
You GUYS are something else, it's like having 10 buddies standing around my motor offering suggestions. Eventually it gets figured out. MUch appreciated.
Old 04-24-2010, 04:09 AM   #11
highperf4x4
Actually timing doesn't cause an engine to diesel after you shut it off. Once you kill the switch, the dizzy has no fire. What causes dieseling is excessive carbon buildup in the cylinders from improper fire or poor mixture. The carbon will become a "hot spot" that causes fuel to continue to ignite similar to a diesel engine which fires by heat and compression alone after it starts hence the term "dieseling".
Bad timing or weak fire may have caused the carbon buildup though. One good thing about it is if your engine is dieseling, it usually indicates good compression.
If it starts to do it again in the future you can shut the motor off in gear and then put it into park. Run some Shell Super Unleaded in it for a while and it might help. It has an upper cylinder lubricant and cleaner in it already.
highperf4x4 is offline   Reply With Quote
Old 04-24-2010, 04:14 AM   #12
beebster
beebster's Avatar
shell sounds like a good idea.
It stopped "dieselling" after i messed with the timing, it was too far advanced.
Old 04-24-2010, 04:16 AM   #13
highperf4x4
Yeah but remember, once you shut the switch off, you get no spark because there's no juice to the distributor.
Old 04-24-2010, 05:49 AM   #14
beebster
beebster's Avatar
hmmm.
good point.
Old 04-24-2010, 09:05 AM   #15
shocker
any chance you had a wire or something else jammed into the mechanical weights of the dizzy preventing the advance from coming on?
formerly cooter
shocker is offline   Reply With Quote
Old 04-24-2010, 01:29 PM   #16
highperf4x4
Anyway, if it starts dieseling again in the future, don't let it go too long before you pull the heads and clean out as much carbon as you can from the combustion chambers (mostly the valves) and the pistons. This excessive carbon buildup and hot spots are what cause you to burn a valve or a hole in a piston especially when you have a lean condition.
Glad you got your dizzy problem worked out though.
