Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
LS swap questions
Is everyone that is running dual tanks having to use the 87 specific tank selector switch? Just wondering because I looked at both of them and they look identical. What is the difference between the two? Thanks
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
BMW & ASE Master Certified
Re: LS swap questions
probally reffering to the 87 fuel tank itself... there is a small baffle/bucket where the fuel pump sits into... the switches are probally the same as i cannot think of a reason why they would be different.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Nope, not talking about the tanks. I know those are baffled. I have had 87 tanks, senders, intank pumps , etc for months now. The 86 and older switch on the dash and the 87-91 switches are different. Just dont remember what is different about them.
Slots go on anything!
I think the later switch powers up the pump when it is switched (I think). Bob or Dennis will know, for sure.
1974 Jimmy- 5.3/4L80e/NP241 |
When I was buying a new selector switch at Autozone, there were two styles. One was a momentary switch for L or R tanks that you held in place to switch the selector valve, then returns to a neutral position, and the other (the correct style for my TBI 87') stays in position for either L or R tank.
I am just unsure which one I need for the LS swap. Bob or Dennis know?
![]() Join Date: Jul 2009
I would think that if you are using 2 seperate pumps, you would have to have the '87 up to maintain power to the f.i. pump.
#8 | ||
Next project: 1970 K10
NAPA usually stocks them, I had to replace mine. NAPA part number ECH FS502, $15.01. This one: ![]() NOT this one: ![]()
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-23-2010 at 12:27 PM. |
OK, I get it now. The relay for the fuel pump will run through the switch and send constant power to the pump chosen where the "depress fully" switch only sends power long enough to switch the valve.
