Old 04-23-2010, 04:43 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Questions on Changeing intake manifold gasket is this normal?
This is the first time ever I have Changed an intake manifold gasket I cant afford to take to a shop.I was leaking oil & coolant from the back by the Dizzy.My truck is a 72 with a 454BB & th400
1. First off what do you guys use to clean everything up without contaminating the inside of the engine? I am tring to keep all debri out as good as I can, can I use carb cleaner or other cleaners to help in removal of old RTV? I know I have to change the Oil and the coolant when I am done.
2."IS THIS NORMAL OR DO HAVE TO WORRY" I was looking at the inside of the engine and noticed these round ring things not sure what you call them but all the rods don't have them looking the same are these round things Normal to be different some up and some down I took some pictures of what I am talking about the rings in question are the ones I have circled in RED and the ones to apear normal TO ME IN BLUE I just want to be sure I don't have a problem later down the line. I guess I can call my self an uncertified Mechanic now Thanks in advance everyone for the help...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 04-23-2010, 05:52 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Questions on Changeing intake manifold gasket is this normal?
Those are your lifters in the circles. They go up and down while the engine rotates. That's completely normal for them to look like that.
Second, tuck a large sheet of aluminum foil into the valley under the intake to catch any RTV shavings and gasket remnants as you clean. Also, stuff a paper towel into each port before you scrape the gasket too. Once the gasket area is scraped clean, pull the paper towels from the ports, then carefully fold the aluminum foil up to catch all the droppings. Dispose of it all.
Then take a minute to make damn sure you have removed all of the paper towels from each and every port.
Old 04-23-2010, 06:43 AM   #3
cdowns
cdowns's Avatar
after you do that you can take a shopvac and go over the valley to get any additional debris
Old 04-23-2010, 07:32 AM   #4
dwaite72lnghrn
One more thing it looks like you are not at TDC on cylinder #1 looking at the lifters. So watch putting the dizzy back in. I normally set TDC when I can Look at the lifters to make it easy.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 04-23-2010, 09:18 AM   #5
truckdude239
truckdude239's Avatar
looks quite normal to me
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-23-2010, 09:20 AM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
It's funny to hear the honest questions of someone that is taking on a task for the first time. The big thing is to try and control the crap getting into the bottom of the motor. You just have to be real careful. Like the fireman said, those lifters are just up on a portion of the cam lobe.
Like Dave said, now is a great time to get the motor at top dead center. You do this be aligning your TDC on your crank to your timing pointer on your timing chain case. Be careful though because one turn will get you at TDC and one will get you at 180* out. You can tell by the lifters when you are on the mark. If you are at TDC, both lifters will be all the way down in the lifter bores. It will look like the ones you have circled in blue.
The other thing I like to do is to try and put paper towels or something in the head ports. You will more than likely need to scrap or remove some gasket material from the heads once the intake gasket it off. Make darn sure you don't have any material at all get into those ports. I've not heard of the tin foil trick but lay something into the valley to stop stuff getting down into the cam area and onto the lifters. When I'm done I also like to vacuum the whole area with a shop vac. Just take your time and watch for stuff falling where it shouldn't be!!!
prostreetC-10 is offline   Reply With Quote
Old 04-23-2010, 09:22 AM   #7
petey-pablo
"THE GREEN GOBLIN"
Cool thanks everyone I just have never done anything like this before and was cought of guard by the looks of the ring things not looking the same all around..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 04-23-2010, 09:26 AM   #8
petey-pablo
"THE GREEN GOBLIN"
I have heard about putting it on TDC prior to doing this but I figured I could just mark the Dizzy and Rotor's location before taking it apart. Hope I din't make the wrong choice.
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 04-23-2010, 09:30 AM   #9
my67chevytruck
Under Construction
my67chevytruck's Avatar
Good tips guys! I wish i would have known the TDC trick, we had the manifold off awhile back switching to an edelbrock... Hmm,, maybe i can convince Kevin ( TX FF ) to come by when im ready to fire.
Petey-Pablo, take your time and ask all the ?'s you need. looking forward to the updated progress pics!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-23-2010, 09:33 AM   #10
petey-pablo
"THE GREEN GOBLIN"
This sounds like a good idea but like I said I have never done this before, Do I still have to set it to TDC even though I marked my dizz and rotor locations? Do I rotate the crank till the pointer on the balencer points to the 0 mark? and what lifters will be all the way down in the lifter bores?
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 04-23-2010, 09:41 AM   #11
Jim_PA
Who else moved closer to the screen to try to find something wrong with the lifters?
It's all good, we've all been there.
Jim_PA is offline   Reply With Quote
Old 04-23-2010, 10:42 AM   #12
panda68
panda68's Avatar
If you didnt rotate the motor at all start to finish the distributor should work fine where you marked it. The lifters will be at different heights because they ride on the cam lobes. Their location in the bores will depend on what stroke the pistons are in either intake, compression-combustion or exhaust. http://en.wikipedia.org/wiki/Valvetrain good luck dude.
horsepower sells cars torque wins races. "caroll shelby"
panda68 is offline   Reply With Quote
Old 04-23-2010, 01:25 PM   #13
crakarjax
crakarjax's Avatar
Hmmm... good idea with the paper towel int he ports. I usually just try not to get crap in the ports and assume that if it does, it will just get burnt and expelled in the first cycle. Probably should play it safe from now on!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-23-2010, 01:41 PM   #14
short-t
short-t's Avatar
There is no right or wrong choice as long as you marked the distributer prior to taking it out.
Some folks like to have the engine at TDC and some will just mark the dizzy just as you did!
short-t is offline   Reply With Quote
Old 04-23-2010, 02:27 PM   #15
DT1
DT1's Avatar
Getting the manifold to set down correctly when you re-install it can be a pain. Even more so when you're
working with a big block that's still in the truck.
Here's a tip I learned a few years back that works pretty well... Get four threaded studs (Or cut off the heads of four cap screws) the same size and length as the manifold bolts.
Screw them just a couple of threads down into the very front and back hole in each head.
The studs will help guide the manifold in place. After threading in a few of the manifold bolts you can remove the studs.
DT1 is offline   Reply With Quote
Old 04-23-2010, 03:42 PM   #16
Tx Firefighter
Leave your distributor on the work bench and call me. If I can't install the distributor right within 5 minutes, on the first attempt I will buy you a steak dinner.
Old 04-23-2010, 04:14 PM   #17
slomotion
Old Duffer
slomotion's Avatar
TX is right, I wouldn't change the engine/dist. relationship now. If you do, your dist. won't seat because of the oil pump drive slot orientation when you pulled the dist. It also matters WHEN you marked the dist. rotor. Before you pulled it? or after it was out? Did you notice the rotor turn slightly as you pulled the dist. up? You have to turn the rotor to where it stopped rotating before you put it back, then when you install it the rotor will turn back to where it was, and also ingage the oil pump drive all at the same time.
Hope I didn't confuse the issue, but a long time ago, I wondered why my dist. wouldn't seat, and it was the oil pump slot not being lined up.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-23-2010, 04:25 PM   #18
my67chevytruck
Under Construction
Thanks Kevin,
I will definitely take you up on that!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 04-23-2010, 05:17 PM   #19
leddzepp
Moderator
leddzepp's Avatar
If your oil pump slot does not line up with the distributor, you can use a slotted screwdriver to rotate it to the correct position.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-23-2010, 06:59 PM   #20
OhOneWS6
OhOneWS6's Avatar
That might work for a Ford but it will never work on a Chevy. Chevy intake bolts are at an angle (Square to the gasket surface).
I never use the end seals that come with the gaskets. Just run a bead of RTV instead. The center 4 intake bolts go into an oil passage. You need to put some type of thread sealant on them or it will seep oil through those bolts. You also need to follow the proper torque sequence when bolting the intake back down.
Torque Specs
OhOneWS6 is offline   Reply With Quote
Old 04-24-2010, 06:54 AM   #21
Tx Firefighter
WS6 hit on a good point. Always throw the end seals away and use a 1/4 inch bead of black silicone instead. Back in the mid 90s I worked in a GM dealership and there was actually a memo from the General posted telling techs to do just that. GM determined it was much more reliable and less liable to cause warranty oil leaks.
Old 04-29-2010, 09:06 PM   #22
petey-pablo
"THE GREEN GOBLIN"
Ok guys I wanna say thanks for everyones help, The job is finally complete I just finished today yup today it took me long enough I got cought up in other things pulled my bumper and front grill off to install the inner grill then back on again. I wanna give thanks to BIGJAKE97 he supplied the torque wrench and helped in the torque down. I put my carb back on today and added coolant the truck fired right up. I took a drive down to vintage chevy trucks here in fremont to pick up some bolts it ran good so far no leaks I have my hood in the bed so I really couldn't get crazy sidwayz I have to wait till the weekend for a longer drive We did good thanks again .............
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 04-29-2010, 09:09 PM   #23
petey-pablo
"THE GREEN GOBLIN"
One last question Should I drive it acouple hundred miles maybe 500 then re-drain the coolant and replace it also change the oil Just in case something might have fallen inside?
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 04-29-2010, 10:37 PM   #24
'72customdeluxe
you changed the oil before you drove right?
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-29-2010, 11:23 PM   #25
HOGDADDY
HOGDADDY's Avatar
I might be a little late but is that a steel core intake gasket and are you installing an aluminum intake? I read posts and didn't see what your using.
If so, it is my understanding that aluminum intakes require composite gaskets (non-steel) while iron intakes use steel core. Btw Edelbrock even sells the composite gaskets for their intakes also.
HOGDADDY is offline   Reply With Quote
