Old 04-23-2010, 07:01 AM   #1
G-REX
700 r-4 converter lock up
I just picked up a 700r4 out of a 1986 Chevy caprice classic that was behind a 305,I want to put it in my 64 step behind my built 350,I have the complete car,so will have other parts.My question is,do I have to rewire trans with a hot wire for the converter lockup,or should I just run it?Tx Firefighter posted a quick rewire does this work for you?Thanks
G-REX is offline   Reply With Quote
Old 04-23-2010, 07:45 AM   #2
greg65
greg65's Avatar
Re: 700 r-4 converter lock up
I bought a Painless wiring kit for the 700r4. I loved having the extra gear and lockup converter.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 04-23-2010, 08:12 AM   #3
G-REX
How about a shifter other than a lokar? any ideas?
Old 04-23-2010, 09:30 AM   #4
cl08
My suggestion would be a B&M Megashifter, Quicksilver, or Prostick possibly a ProRatchet. I Megashifter (ratchet) in a S10 Blazer with a small block and 700r4 that is built (rev manual valve body, gears, vette servo, 3500 stall converter). I like the ratchet shifter in it. But it is being redone and are switching to a ProRatchet. Just my two pennies.
cl08 is offline   Reply With Quote
Old 04-23-2010, 09:32 AM   #5
awire007
I have the 700r4 behind a 350 with the B&M Megashifter and I LOVE IT.
awire007 is offline   Reply With Quote
Old 04-23-2010, 09:47 AM   #6
greg65
greg65's Avatar
When I was still driving mine it had a Prostick. I had to swap out the plate to go from a three speed auto to a foer speed auto.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 04-23-2010, 09:51 AM   #7
G-REX
I have a B&M ratchet /gate shifter,for 3 speed auto,can I alter or change anything to make it work for a 4 speed auto,anyone ever done this?
Old 04-23-2010, 09:58 AM   #8
G-REX
I should have said B&M star shifter
Old 04-23-2010, 10:06 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
You need to be able to lock up the converter. It will create to much heat if you don't. Just wire it and use a toggle switch. I did that for years and I liked it as I could control the lock up myself.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-23-2010, 10:08 AM   #10
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I'm still running the old z-gate from my previous 400, I just have no way of holding it in low gear. love the manual lock up, I think I have a TCI kit off of e-bay, didn't spend big bucks. haven't seen Tx Firefighter's diagram but wouldn't hesitate to try it.
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-23-2010, 10:13 AM   #11
Chevy Fleetside
I used a automatic column out of a van. Gee I am so boring, but I got it at pick n pull for $28. it looks like this one except cleaner.
Old 04-23-2010, 10:17 AM   #12
awire007
How do you tell if the lockup is working properly? On mine at low speeds I feel a clunk that feels like a downshift on a manual transmission (it's a stage 2 700r4) Is that the lockup releasing?
Old 04-23-2010, 10:22 AM   #13
awire007
I think the star shifter is 3 speed only: http://www.fastpts.com/cgi-bin/hazel...mshifters.html
On my Mega Shifter I had to remove a couple of pins & swap out the plate that shows you what gear your in.
Old 04-23-2010, 10:23 AM   #14
awire007
Did it require any fabrication? What year model van did it come out of?
Old 04-23-2010, 10:36 AM   #15
greg65
greg65's Avatar
With the Painless kit the lock up work fine on the highway. My 406 has a big cam so around town when the converter locks up the trucks starts to buck and jerk. This is at speeds under 55. To solve this I installed a toggle switch to lock the converter up when I choose to.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 04-23-2010, 10:48 AM   #16
JRBECK64
Is there anyway to use the original Automatic Steering column thats set up for a three speed automatic when installing a overdrive tranny like a 200R4?
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 04-23-2010, 10:55 AM   #17
G-REX
So you need to lock up tranny in overdrive only?Or is it the whole time through all gears.I f I use my z-gate ,I won't have L1?Here is diagram from TX FIREFIGHTER.
Old 04-23-2010, 11:13 AM   #18
Chevy Fleetside
JRBECK64
Yes you can. I am using a 3 speed auto column from a van. It would be a 70's van column.
Old 04-23-2010, 11:16 AM   #19
Chevy Fleetside
These columns come from 70's vans. I think all the way up to 1979 or 80 are the same. I welded two nuts to the bottom of the column so I could bolt it to the coliumn/hand brake bracket. I also used the lower column from a 73 and up truck.
Old 04-23-2010, 11:17 AM   #20
JRBECK64
[QUOTE=Chevy Fleetside;3936495]Yes you can. I am using a 3 speed auto column from a van. It would be a 70's van column.[/QUOTE
Chevy Fleetside,
I guess that the drive position would actually be the overdive position and you just wouldn't be able to manually shift the tranny into L1, would that be right?
JRBECK64
Old 04-23-2010, 11:17 AM   #21
Chevy Fleetside
You can't lock up in all gears. it shouldnt lock in 1st and if you forget to turn it off you will figure it out real fast when it shifts into 2nd..
Old 04-23-2010, 11:21 AM   #22
G-REX
I guess I could make the steering column from the caprice work,just some fab work,and linkage,and would leave more leg room.Also run wiring with switch right on shifter arm.
Old 04-23-2010, 01:03 PM   #23
Russ65C10
Russ65C10's Avatar
B & M makes a great pull and play lockup controller that's allows you to manually adjust the lockup. I put one in when I installed my 700R4 I think at the time it cost about $150 but it was worth it.
You can use your 3 speed colume (automatic) you just need to get your self a 4 speed indicator to mount on your colume in place of the 3 speed. I used the original powerglide colume and shift linkage all the way up though my 200R4.
Russ65C10 is offline   Reply With Quote
Old 04-23-2010, 04:24 PM   #24
jkb
I used a kit from Jegs that uses vacuum to control the lock up. Heres the link: http://www.jegs.com/i/TCI/890/376600...oductId=748599
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
jkb is offline   Reply With Quote
Old 04-23-2010, 05:29 PM   #25
Joemomma1
Joemomma1's Avatar
Thats the same kit I got but have yet to install. How do you like it? Its seems the instructions make it look tougher than its actually is.
Joemomma1 is offline   Reply With Quote
