04-23-2010, 08:32 AM | #1 |
Dropmember (Do you need to go to 2 pc driveline)
I'm getting ready to buy a dropmember for my 72 swb. My question is Do I have to run a 2 pc driveline??? Second How do I tell if I have a small hump or large hump tunnel???
04-23-2010, 09:35 AM | #2 |
67cheby
Re: Dropmember(Do you need to go to 2 pc driveline)
its easier if you use a 2 piece , if you use a one piece you will have to tunnel the cab floor, on the hump if it bolts in its a high hump if it is welded in it is a low hump
04-23-2010, 09:36 AM | #3 |
67cheby
heres a pic of the high hump
04-24-2010, 10:51 AM | #4 |
Great! that helps alot!
05-15-2010, 03:07 AM | #5 |
Kvn1011
Re: Dropmember (Do you need to go to 2 pc driveline)
are there any aftermarket high humps available??
ive check from craigslist to ebay and cant find one |
05-15-2010, 03:37 AM | #6 |
67-72 parts collector,…
Check in the classifieds section. They ususally show up there.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-15-2010 at 03:38 AM. |
05-15-2010, 04:15 AM | #7 |
Kvn1011
Ok,will do,thnx
05-15-2010, 04:32 AM | #8 |
so if you have a high hump you don't have to make a tunel ?
05-15-2010, 04:55 AM | #9 |
Kinda correct.
The high hump helps with the fact that you raise the engine/trans combo when using a Dropmember. If you use a 2-piece driveline you won't have to tunnel the floor for driveshaft clearance.
05-15-2010, 05:00 AM | #10 |
My truck is a high hump what other mods do you have to make to instal a drop member thanks for the info Tony
05-15-2010, 05:11 AM | #11 |
Look at this tech article from Nate's website.
http://porterbuiltstreetrods.com/sit...hristmas-time/ Lots of good info and pictures. What year truck are you installing the Dropmember in?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-15-2010 at 05:11 AM. |
05-15-2010, 05:18 AM | #12 |
69 swb getting all the parts together c-4 drop member nice blazer in your avatar
