Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-23-2010, 10:22 AM   #1
Murphy IRE
Proper elec hook up for radio
OK while I have the dash out, I want to fix the radio. It's an after market Pioneer Cd/radio. The PO wired the radio on a hot only circuit. I want to tie in on the ACC mode and have it work when the truck is running.
Thanks in advance for the help.
Murphy IRE is offline   Reply With Quote
Old 04-24-2010, 08:10 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: Proper elec hook up for radio
Sounds like a simple job. It's should take 3 wires; ign, acc, and ground.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-24-2010, 10:23 PM   #3
70C10Toejam
Hellasick
70C10Toejam's Avatar
Just hook the main power lead to the radio terminal on the fuseblock. Leave the memory lead connected to the always hot lead or else your radio will forget things.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-27-2010, 08:55 AM   #4
Murphy IRE
There are still flags on the wiring for the radio.
The Red wire which has the in line fuse says ACC. Should this be pigtailed into an ign hot wire?
The yellow wire says battery. So I'll splice the yelllow line into a hot wire.
Old 04-30-2010, 12:13 AM   #5
Murphy IRE
OK I got the wires figured out. Yellow to always hot and red to IGN connector. I checked and I have power into the the back of the radio all the time with the yellow. The IGN wire has power when turned on. The wires are hooked up correctly, according to the instructions. BOTH fuses are still good, but nothing happens. The ground is good.
CONFUSED.
Old 04-30-2010, 10:05 AM   #6
jcsbrat
jcsbrat's Avatar
Does the head unit itself have a fuse under the wire harness? And i mean under it like disconnect harness from head unit. Or anywhere else thats not in a wire line? If so it may have popped during all your trial and errors. Or in case you havent check you might have blown a fuse in the fuse box when you werent looking. If thats not the problem does the unit work when you just go hot all the time?
jcsbrat is offline   Reply With Quote
Old 04-30-2010, 12:50 PM   #7
Murphy IRE
It's good and so is the in-line!
Old 04-30-2010, 01:11 PM   #8
jcsbrat
jcsbrat's Avatar
And does it work when just red and yellow are together running "hot" all the time?
Do you have the ACC wire hooked up to the "radio" space in fuse box? If so, is tester lighting up when touching spade? On the bottom three fuses if fuse box is vertical the 1st and 3rd fuse should work when key is in all three positions (ACC/Start/On) if temp plug there you will maybe can start eliminating.
Old 05-03-2010, 11:16 AM   #9
jcsbrat
jcsbrat's Avatar
Did you get this taken care of? If not i can try and post a pic of where my wires are connected at in fuse box.
Old 05-03-2010, 05:45 PM   #10
Murphy IRE
I haven't gotten to the radio, I've been fighting bigger battles on the heat/AC system. A diagram would be great!!!.
Thanks alot
Old 05-03-2010, 05:51 PM   #11
jcsbrat
jcsbrat's Avatar
Actually I found what id tell you in another members thread. the tread is PROJECT BLANK SLATE in PROJECTS AND BUILDS. its about 1/4 of the way down his first page. If that still dont help give me a hollar.
K-
Old 05-03-2010, 11:04 PM   #12
Murphy IRE
Found it. I think that's what I eventually did, but I'll check it tomorrow. I did something else at first and I'm hoping that I didn't cook it! I'll double check the red wire connections on the in-line fuse holder. It wouldn't be the first time one of those came lose.
Thanks,
Old 05-04-2010, 08:12 PM   #13
Murphy IRE
Don't Know what I did, but the new Kenwood works great.
Thanks for all the help and suggestions!
