OL BLUU
![]() Join Date: Mar 2004
Info::
These wheel spacers came off a 2001 Jeep Grand Cherokee overland. They are 5x5 bolt pattern and are 1.25" wide. The OD of the hub centric portion is 70mm. These should fit the rear of a 5x5 wheel a Rally wheel correct? Thanks guys! Anthony
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
yeller
Re: Quick question: Will these fit my Blazer?
With that lip in the center, I don't think they will work. All the spacers I have used have been flat there. I guess it depends on the size of the hub...but I am skeptical.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
TUKE-NoBullChit Customs owner
well i think the factory rallies have a 3" center hole, which is also 76mm if im not mistaken so i would think the 70mm is fine, shouldnt be a problem. just make sure when you put them on that your factory studs and lugs dont stick out past the adapter
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now) http://www.facebook.com/#!/nbc.customs ![]() |
![]() Join Date: Jul 2009
They should work fine. The center bore on the rally's is 70.3mm, so they should work really well.
BMW & ASE Master Certified
not going to work.. the center of the rally wheel is 3.0" (or real close to it) which is 76.2mm... the wheel will fit the adapter, but the adapter wont fit the rotor, which as a 76.2mm register to center the wheel on to the rotor. same deal for the rear.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
X2. Unless you know a machinist that works for cheap.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
Happy to be here
![]() Join Date: Mar 2000
My question is why? What are you trying to accomplish?
OL BLUU
I was looking into those to move my rear Rally's on the Blazer out. If they were going to work... I would of bought them and sold the other pair to someone else.
