Old 04-23-2010, 02:55 PM   #1
72GREENC10
72GREENC10's Avatar
air fittings help
does anyone know any local stores like hd, lowes, ace hardware, harbor freight ect, where i can get fittings for my tank? and where i can get 1/4 air line?
thx. cj
72GREENC10 is offline   Reply With Quote
Old 04-23-2010, 03:22 PM   #2
michael bustamante
michael bustamante's Avatar
Re: air fittings help
air fittings Ive been having pretty good luck with lowes or home depot, (compression fittings, not pushloc)but USE the BRASS FITTINGS!!. Those plastic ones seem to have a bad rep here.
as for 1/4 line, you will be best off going to a truck store for that, Ive been going to freightliner myself.
Oh and if youre going to use guages, The only place I could find 4 way fittings is at ace hardware, or a plumbers supply
1967custom
michael bustamante is offline   Reply With Quote
Old 04-23-2010, 04:48 PM   #3
royo
royo's Avatar
Look in your phone book for a FleetPride, Truck pro, Or world wide equipment they will have what your looking for on hand
http://www.fleetpride.com/fp_c/loc07_info.html
nickle and dime
royo is offline   Reply With Quote
Old 04-24-2010, 10:15 AM   #4
Shane
Shane's Avatar
Not sure if they have stores in your area, but our local FASTENAL has a really good selection of Push To Lock fittings.
If you are located close to a larger city you may want to look thru the yellow pages for a Parker Store. They WILL definitely have what you need.
Shane is offline   Reply With Quote
Old 04-24-2010, 05:11 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
also Grainger
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-26-2010, 06:30 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
X2 on Fastenal!
Just make sure they are DOT approved fittings.
Our local store had to order them,... but it only took a couple of days.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 04-26-2010, 08:24 PM   #7
colin_havens
colin_havens's Avatar
I bought all of my puch to lock fittings from NAPA. The local store when I lived right outside Memphis had them in stock. All brass, and a solid seal on DOT line. Be prepared thought as they werent cheap, but maybe thats because I used all 1/2 inch fittings and line
colin_havens is offline   Reply With Quote
