axle seals 83 chev k10 4x4
good day all can someone tell me if the axle seals are inner on my truck and if so a breakdown on how to change them out. also just changed trans seals and still leaking there was this rubber washer thing that looked like a gear would that be the reason for it still leaking any help would be good thanks
![]() Join Date: Apr 2005
Re: axle seals 83 chev k10 4x4
On the rear:
Don't know about the front, mine's a 2wd so it's completely different. Last edited by Turbo85GMC; 04-23-2010 at 04:05 PM. |
my bad I should have said what axle (front)
#4 | |
The inner axle seals on the front axle require a complete tear-down of the entire axle. The only thing left is the pinion...drive shaft removal is not necessary either.
The seals are removed from inside the differential cover after the carrier is removed. This of course means that the axles have to come out too, thus requiring hub/rotor and spindle removal too. It is a rather complex thing for such a simple little seal....and it gets you into a few "while you are in there" jobs too. The axle joints should be replaced, wheel bearings re-packed, wheel seals replaced, and I would take a good look at the ball-joints....."while you are in there". You will probably find that removing the spindles will be the hardest part of this process.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
