Old 02-09-2003, 07:05 PM   #1
bigjimzlll
bigjimzlll's Avatar
WOW!!!!! new cam heads
WOW..I switched from a comp 268H to a comp cs268-s10 and had my heads(186) re worked..It used to stop pulling at around 5.000rpm...now it pulls like mad all the way tp 6000..better throttle response..and wicked long powerful smokey burnouts..and this is with out any N20..I cant wait for the track to open
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-09-2003, 07:08 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
Sounds alright, cant wait to get mine to the driving stage, still in the body work phase though.
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 02-09-2003, 07:08 PM   #3
GMC71k20
lets see some smokey burnout pics
GMC71k20 is offline   Reply With Quote
Old 02-09-2003, 09:21 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Congrats Jim!, Sounds like solid cams are a blast. I didn't get mine installed this weekend. Next Saturday I hope.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-09-2003, 10:11 PM   #5
68 Suburban
68 Suburban's Avatar
What is the difference between those two cams??? Thanks
68 Suburban is offline   Reply With Quote
Old 02-09-2003, 10:12 PM   #6
bigjimzlll
bigjimzlll's Avatar
yea they are a blast...make sure to adjust the rockers after the cam break in(hot) they do change a little..I just cant believe the difference..I dont know if the cam or the heads(or combo of both) made the big difference..I still have my restrictive 2" exhaust on it..the flowmasters will go on tomorrow if I have time.
Anderson,CA
Old 02-09-2003, 10:41 PM   #7
bigjimzlll
bigjimzlll's Avatar
heres the 268H(hydrolic)
Part Number 12-210-2
Engine 1955-present Chevrolet
262ci-400ci
8cyl.
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.454 0.454
Duration At 0.006 Tappet Lift 268 268
Valve Timing At 0.006
Open Close
Intake 28 60
Exhaust 68 20
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 218
Lobe Lift 0.3026 0.3026
Lobe Separation 110
Recommended Valve Springs 981-16
hheres the soild lifter....
Part Number 12-676-4
262ci-400ci
8cyl.
Grind Number CS XS268S-10
Description
Intake Exhaust
Valve Adjustment 0.016 0.016
Gross Valve Lift 0.488 0.501
Duration At 0.015 Tappet Lift 268 274
Valve Timing At 0.015
Open Close
Intake 28 60
Exhaust 71 23
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.325 0.334
Lobe Separation 110
Anderson,CA
Old 02-09-2003, 10:42 PM   #8
neonlarry
neonlarry's Avatar
Now, all you need to do is fix your signature. lol
Sounds like the modifications were well worth it. It seemed fast before when I rode in it, I guess if I am up there I will have to come by and visit you again.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-09-2003, 10:43 PM   #9
nate68
the redding track is gonna start having grudge drags like twice a month this upcoming season. they start in march
www.reddingdragstrip.net
i'm looking to take my truck at least once this year. time's won't look great at least until i get a posi. 406+non posi=no traction
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 02-10-2003, 03:34 PM   #10
Tracy Focht
Tracy Focht's Avatar
Sounds good...I know the cam helped, but the heads were sure adding to that new combo. Glad it brought the smile back.
Tracy Focht is offline   Reply With Quote
