![]() Join Date: Apr 2009
Time for the Shaft, driveshaft that is
Anyone ordered a drive shaft over the web? Would you recomend changiong the pinion yoke from my small u-joint cap (3110?) to the larger 3150? Its for a stock 454 and 400th. Has anyone changed there yoke?
"All Alone Meet & Greet 2010." http://67-72chevytrucks.com/vboard/s...d.php?t=393754 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Time for the Shaft, driveshaft that is
I'm running the original size yoke and u-joints in my Suburban and haven't had any trouble with them. I'm not real hard on them, but I do have my foot in it most of the time.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-24-2010 at 12:04 AM. |
It's Better With Nitro
If you are changing out your driveshaft to a custom unit, I would recommend upgrading everything to accept a Spicer set up. And, yes, I have ordered dozens of driveshafts over the Internet for my cars, as well as customer cars. Most of my purchases have been through Mark Williams, But did order a driveshaft from Denny's as a customer request.
