![]() Join Date: Dec 2001
Fan shroud problem
Replaced the radiator in truck,now the fan hits bottom of shroud. It is a 3 row radiator but it fits perfect.Has anyone had this problem before?
The other radiator was 2 row. I also replaced top support pads. Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 04-25-2010 at 12:43 PM. |
![]() Join Date: Sep 2005
Re: Fan shroud problem
i'd liek to know this my self i replace the motor in my turck and not mine hits on the right side
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Currently Blazerless
Sounds like the bottom clips that hold the shroud may be up and out of the slot they fit in.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
![]() Join Date: Sep 2000
might check the bottom support pads and retainers,
69 stepside, 1/2ton, 4X4, 350/350/205 |
Is there a difference between upper pads and lower pads?
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
According to LMC catalog, the pads are the same upper and lower. 2 and 3 core use the same and 4 core uses a wider set.
![]() 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! ![]() |
