View Poll Results: What to do for the rear lift???
Find the heaviest duty 4 inch rear springs I can 9 39.13%
Shackle flip with the original rear leaf springs. 9 39.13%
Original rear springs with a 4 inch block (my least favorite). 2 8.70%
Leave it stock height front and back if I ever want to pull safely. 3 13.04%
Voters: 23. You may not vote on this poll
Old 04-23-2010, 11:09 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
What to do, what to do? Rear lift question
Here's the background, I just got the 78 in my signature and plan to have a little fun with it but do it on a pretty low budget. As my sig says, its a 78 K20, 454 4-speed. I will need to pull a bumper-pull trailer from time to time and possibly even a gooseneck here and there (it already has a hitch in the bed). My plan is a 4 inch lift with 33 inch all terrain tires. In the front, obviously will be new lift spring, but what do I do with the back? I can't get a straight answer from anyone as to whether or not aftermarket rear lift springs can be bought in a 3/4 ton capacity or if they are all basically 1/2 tons. So vote and let me know, keeping in mind frugalness, the fact that I want to keep my 3/4 ton capacity, and some trailer pulling from time to time...lets say no more than 6000 lbs.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-23-2010, 11:44 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: What to do, what to do? Rear lift question
I didn't see the option for lighting it on fire and pushing it off a cliff so I chose HD springs.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-24-2010, 01:04 PM   #3
USSkoval
What length are your springs? 56? I think any rear lift spring is going to ride stiffer than stock. I don't think a replacement 56" is going to be built with a 1/2 ton in mind, no matter who makes it. Nearly all 1/2 tons used 52's.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-25-2010, 11:47 AM   #4
Critter
Future TOTM Winner
Critter's Avatar
I have a terrible memory, but aren't all 73-87 rear springs 56" regardless of tonnage? 67-72 rears are all 52.
That's why front lift spring kits with rear blocks are all the same for 67-87, but a full lift kit including rear springs is a different part number from 72-73.
Old 04-25-2010, 02:00 PM   #5
USSkoval
Nope, most 1/2 tons use 52" rears for '73-'87. Also, I could have swore '67-'72 front springs were a little shorter than '73 and up. I could be wrong though.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 04-25-2010, 07:12 PM   #6
Bo Duke
Bo Duke's Avatar
If the stock springs aren't sagged out, then there's no reason to get rid of them. I vote shackle flip. You keep your weight capacity and save money.
Buying front lift springs is the easiest option, but look into the B52 swap.You can run used stock rear 52" half ton springs up front and gain 4" of lift. It takes a little fab work, but you'll have more flex and a better ride than any lift spring will give you.
Bo Duke is offline   Reply With Quote
Old 04-25-2010, 09:06 PM   #7
martindc1
My old 01 Cummins Dodge had some huge lift blocks in the rear stock, and it was ok.
But my vote was for keep it at stock height, but thats just the way I am. On my truck I'm going to do an add-a-leaf in the rear to bring it up a bit and keep the stock height in the front.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 04-26-2010, 03:49 PM   #8
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
shackle flip ftw
Eturnit3 is offline   Reply With Quote
Old 04-27-2010, 02:01 PM   #9
Oilbrnr
Oilbrnr's Avatar
Get 4" springs and add the bottom leaf off of the originals. I would not do shackle flips for towing. Not to mention, the springs are probably tired anyway.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 04-27-2010, 10:20 PM   #10
martindc1
In practice, can these springs really get tired? I know some tend to say over time, but on the other hand the springs on my 67 seem to be going strong.
One thing with the shackle flip is that it will shift your rear axle forward some.
Old 04-27-2010, 10:28 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
Why is that???
That's what zero rates are for.
