04-24-2010, 10:18 AM | #1 |
5 lug versus 6 lug - recommendationSS please
I have a 68 swb truck I purchased last fall. The pervious Owner had converted the front suspension to a 5 lug 5", disk brakes with 2 1//2 drop. While the rear axle is the original 6 lug 5.5, drum brake. Of course this currently makes for miss matched wheels.
I have located a "Halibrand - Kidney Bean wheel with a Mag-Coat finish" that I like. After talking with Halibrand they will make a set in 5 lug or 6 lug, 16" 17" and 18". They will also make custom back spacing as needed. They're not cheap and they're not expesive. But I would like the lugs count to match. Is this where I'm making my first mistake????? comments appreciated. Here are my Questions: Please feel free to give me your opinionSS. 1. As I understand the change to disk brakes has already changed the front back space. Can anyone confirm. PS, I don't know whose converstion kit was used. 2. I've located wheel adaptors that go both direction 5 lugs to 6 lug and also 6 lug to 5 lug. However, these are 2 inches thick and I have never been a fan of spacers/adaptors. Are they safer than I assume???? 3. THIS IS REALLY WHERE I THINK I NEED TO BE. Do I convert the front disk (remembering I don'y know the manufacturer) from 5 lug to 6 lugSS???? and leave the rear end alone. OR do I find a axle shaft shafts and bkakes to convert the rear to 5 LugSS?? Rear is air bagged and frame is notched if that has any bearing. 4. I've seen, but I wasn't considering it, drum brake to disk brake conversions for the stock rear axle. I think if I only changed the axle shafts that conversion would also work. Any thoughtSS ?? Please, anyone's answers will be appreciated. thank you 327-C10 Last edited by 327-C10; 04-24-2010 at 03:46 PM. |
04-24-2010, 11:08 AM | #2 |
Happy to be here
Re: 5 lug versus 6 lug - recommendationSS please
If it were me I would buy the conversion axles to replace the rear. Since your front is already updated with 5 lug and disc brakes, leave it alone. Change the rear to five lug with new axles, and ad discs there if you like.
In my mind those wheels are going to look better in a 5 lug version. A set of 18's with disc brakes all around would really rock your ride...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-24-2010 at 11:12 AM. |
04-24-2010, 11:33 AM | #3 |
optomistic ah-so
Buy both sets of wheels and give me the ones you don't use JK
Converting either way is about the same expense. Wheels don't seem to be easier to get until you go to passenger car bolt patterns, and converting all four wheels takes up anything you'd save there. Since the money comes out to be a wash, it amounts to personal preference.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
04-24-2010, 12:51 PM | #4 |
67/68/69 6lug rear is narrower than 71/72 most 70 rears are the same as 71/72 .If you are going to use a deep dish rear wheel and not so deep on the front I wold just have rear axle flanges welded up and drilled to 5 lug pattern. If using the same size wheels front and rear I would locate 71/72 5 lug rearend to swap so front end is not wider than rear.
04-24-2010, 12:57 PM | #5 |
04-24-2010, 01:13 PM | #6 |
Watch out for your cornhole !
Early Classic Enterprises sells a kit to convert your 6 lug rear to five lug.
As far as the Hallibrands, I wish you lots of positive luck. Lots of guys over the years have given up on ever getting wheels from them. They never seem to deliver as promised. It doesn't help that the company has been through a string of financial changes over the years either.
04-24-2010, 02:51 PM | #7 |
Project Junkie! Fishing Poor!!
The easiest remidy is just buy 6 lug rotors. They should be a direct bolt. Everyone that I know uses the 1 1/2" spindle pin so the conversion rotors will work fine for you. By the way, we have a set in stock.. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-24-2010, 07:07 PM | #8 | |
Happy to be here
04-24-2010, 07:16 PM | #9 |
Moser Engineering in Indiana will plug and re-drill your axles for 5 lug. I think they charge $85 a pair + shipping. Website is www.moserengineering.com, look under tech info.
04-24-2010, 10:27 PM | #10 |
I have a five lug rear and six lug for sale joe 1-718-634 1268
04-24-2010, 10:35 PM | #11 |
I say change the rear to 5 lug. But like junkie says, I'd grab a 71/72 rearend. My truck is a '72 and I went with 8" rims in the font and 10" in the rear and they both look flush to the body.
04-25-2010, 01:31 AM | #12 |
The 6 lug rotors seem like a no-brainer to me. You can sell the 5 lug rotors you pull off and probably not limp too badly...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
04-25-2010, 09:28 AM | #13 | |
I really liked the idea of sending my axle shafts to be plugged and drilled as 5 lug. Thanks for all the help to date. 327-C10 |
04-25-2010, 09:56 AM | #14 |
If you do the axles, I'd do it locally. Shipping will kill you on two axles...
