Old 04-24-2010, 12:50 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Non-factory Radiator
I'm in need of a radiator before I can get my truck on the road. Right now all I have is a 250 I-6 so I don't need much cooling, but plan to be a Small block V8 by the end of the year.
Anyone running a radiator out of a different vehicle other than a 67-72 truck? How much modification did you do to use it? Not the universal ones, but something I could get at the local bone yard. Thanks.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-24-2010, 01:13 PM   #2
rcbildr
rcbildr's Avatar
Re: Non-factory Radiator
Back when I had my 71 pick up I used a radiator for a 73-87 truck. IIRC my friend bought it for his 76 chevy truck and never used it. I lucked out because the radiator fit perfectly. If you need me to I can measure it tonight and post them dimension tomorrow. The only problem I had was with the lower hose...the outlet on the radiator was smaller (I think) and I could not use the stock hose.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 04-25-2010, 02:12 AM   #3
usmcchevy
usmcchevy's Avatar
Thanks Rcbildr, If the radiator fits in the mounts I can figure out the hoses.
Anyone else???
Build thread
LSx Swap FAQ index
Old 04-26-2010, 12:52 AM   #4
usmcchevy
usmcchevy's Avatar
How about a rad out of a '94 C1500? I can get a brand new one for cheap.
Build thread
LSx Swap FAQ index
