04-24-2010, 04:02 PM | #1 |
wanting to run on e85
not sure if it belongs here but can change it if so.
im lookin to run on e85 know a little bit from reading around on the web i have a 70 chevy c10 350 4 bolt main forged Crank pro top line aluminum heads 72cc chamber all retro roller rocker rubens racing cam 292/300 @50. 540/555 lift 144 b&m blower with flat top pistions holley dp 850 4150 marine carb- but also have a 750 holley dp aluminum fuel tank holley electric fuel pump. compression ratio is about 9:5-1 mallory unilite disb. with MALLORY 685 HYFIRE VI DIGITAL figured we could get more boost with the e85 and around around 5-7 pounds of boost saftly. i been lookin at a a couple places that sell carb kits,but ones around 80 and others range from 290 and up. lookin to convert the 850 marine because it seems to be better to run with the supercharger going to be a street truck pretty much a daily driver. but mite see some track but nothing to serious just for fun. may run nitrous later but not for awhile. not sure if there is anything else to be said but can proivde more infomation if needed. |
04-24-2010, 04:08 PM | #2 |
Re: wanting to run on e85
One thing you gotta remember is alcohol burns twice as fast as gasoline. I assume availablility isnt a problem out there? I know around here e85 is real scarce. I would personally stay in the realm of whats possible with 93 octane pump gas. Mileage will be better and you can get fuel anywhere. You need to ensure all fuel lines and the pump are alcohol safe. You also need alcohol safe needles and seats as well as gaskets. You will need much larger jets. You will also need to make sure your fuel system is capable of flowing enough fuel.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-24-2010, 04:14 PM | #3 |
yes its commen here. and my lines are safe and the kit i found changes everything to be able to run saftly http://e85carbs.com/products.htm is where i found the kit
04-24-2010, 04:27 PM | #4 |
That should cover it for the carb. Your likely going to need to purchase extra jets to get it tuned for the boost though. I would call them and ask if they have a kit geared toward blower setups. I havent messed with any e85 setups to be honest with you. The stuff just isnt available around here. Have done alcohol engines but thats a whole different animal. Usually in the 14-1 compression range just straight drag engines. Generally in alcohol engines and im sure it would apply to e85 as well is the amount that ends up in the crankcase because of slipping past the rings. I would imagine in a blower app it would get worse. Just throwing out some things to take into account on a street engine.
04-25-2010, 02:27 AM | #5 |
At the body shop.
My dad always joked... Take jets completly out for alcohol. LOL
" That didnt make it any newer " " Dont antique the equipment " |
04-25-2010, 11:31 AM | #6 |
Pretty much. It sure does drink it quick.
04-25-2010, 07:36 PM | #7 |
we are testing it in my buddys race car, so far so good. it just smells like poo-poo compaired to the c16 vp that we where running in it.
04-25-2010, 09:55 PM | #8 |
Ive seen jets for alcohol in the 140-180 range so yes they are VERY large but e85 is a man made version so it can be mixed with regular pump gas so try regular pump gas first then if it makes noise or needs more timing add some 85 on top. I was planning on doing this also but if I need I will just splash on top of 91 cause thats all I can get from the pumps here. Coop has e85 local. If you search E85 you should find some in the engine section. Good luck.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-26-2010, 02:25 AM | #9 |
I just ordered some new injectors and a new cam. I'm making the switch as well, but I'm fuel injected. Hopefuly it all works out for you...
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-26-2010, 06:11 PM | #10 |
04-27-2010, 01:49 AM | #11 |
Factory 99-02 F-body PCM.. I use hptuners to dial it in. I do have a Accel Gen7 I was going to put in the Camaro. Selling the Gen 7+ system though. It's for LS/manual trans.
04-27-2010, 11:21 PM | #12 |
60-66 Nut
Would that be the 411 PCM?
