Who's got steelies?
![]() Join Date: Feb 2006
HELP! SM465 shifter lever removal
Time to ask the experts! How do you remove the handle from the SM465 tranny? I've got the removable high hump floor cover off, but don't know what to do next?
Can anyone help?
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: HELP! SM465 shifter lever removal
Get you a pair of needle nose pliers, and open them up and push down on the front and rear of the ball joint looking piece and pull up and maybe twist to the left on the shifter. Sometimes they make you curse a little bit, but once you take one out, it's pretty easy to do one again. Hope this helps, Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
As Trevor indicates, push down on the half sphere on the bottom of the shift lever and as you do, turn the whole shifter - it will pop out. You only have to turn it less than a 1/4 turn. Make sure you have the transmission in neutral before you do it.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Who's got steelies?
Thanks guys! That's why this board is awsome!
Sounds easy...guess I'll find out this weekend!
"Hooked on Quack"
great post I was wondering the same thing. I need to take mine out to paint my interior and fix the hump there is a hole that the PO patched with very thin tin material I am gonna replace with steel.
Semper Fi, Kevin ![]() ![]() |
I used a wooden dowel to push/twist/pop mine out. Then you can look inside and see why those transmissions are so bomb proof.
I followed your directions but still can't seem to free up my shift lever. It looks like there might be a roll pin in mine. Do I need to pull the pin out?
If anyone figures out how to remove the slop from one will you post it up?
-Scott- |
I menuvered my CH465 down and out without removing my shifter. You might have to lift the truck a bit. Just make sure it's blocked up with good jack stands.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
PS My seat was out too which might make things easier.
If anybodys rebuilding one of these please post it up
1969 Chevy c20(Miss Hackjob) |
#13 |
It's been a while since I've looked at mine, but if your shifter has a lot of slop, you'll want to check where the shifter pawl is fitted into the end of the shifter. If you remove the roll pin and pull the pawl out of the end of the shifter, there should be a pair of o-rings. If those are missing (like mine were) you'll have a lot of slop. I replaced mine with the largest diameter o-ring stock I could compress into there. It tightened my shifter up considerably. Of course, shifter slop is all relative. This transmission will never have a tight pattern
Dave 1971 Chevy K10 1972 Chevy C10 |
#14 |
I got mine out! I pushed down on it with a cresent wrench lying on top of where the lever connects into the trans. By the way I' am new to the forum.
#15 |
welcome,
I need to remove mine because it's stuck in 1st gear
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 02-13-2011 at 09:30 PM. |
#16 | |
Some of the newer versions also have a rectangular sleeve that fits up in there to provide isolation instead of o rings, but the same concept. If you don't mind a little shifter "buzz" at times, you can weld it up solid. Won't hurt anything and it will be as tight as can be! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
