Old 04-24-2010, 09:08 PM   #1
JMac11
JMac11's Avatar
Annoying ebrake rattle....
As I have sealed up my 84 4x4, new rattles appear with every improvement. I finally fixed one tonight that had drove me nuts. The rattle always seemed to come from the e-brake assembly and was really apparent if you went over cracked pavement or over lane delineators. These situations are hard to duplicate in the driveway, and I had tried placing a furniture felt between the pedal and the stop it rests against, nothing. Then I tried slicing a vacuum line and placing it against the frame, still wobbled and rattled. So again I contorted under the dash to check all bolts and finally found the culprit. Behind the switch for the brake light when the e-brake is applied is a 1/2 bolt that must be the first bolt they put in when assembling a square body. It took every half inch socket and wrench I had but I finally got it tight..... ah, another rattle sent to its great reward.
JMac11 is offline   Reply With Quote
Old 04-24-2010, 09:14 PM   #2
78 Chevyrado
Re: Annoying ebrake rattle....
I had that same bolt come loose on my 77 and 78. It was a pill to fix, but well worth it!
78 Chevyrado is offline   Reply With Quote
Old 04-24-2010, 10:12 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Hmmm, I wonder if that's what my rattle/squeak is too? It seems to be coming from that same area.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-24-2010, 10:20 PM   #4
73chevyman
73chevyman's Avatar
my e brake cable rattles on my exhaust when theres weight in it annoying as hell
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
