what to paint the dropmember with?
i really need the answer to this. i need a durable paint to do my frame and front dropmember with. i do not want to powdercoat it just in case i forget something during assembly. i dont want to spend a ton of money on show quality paint either. i am going to sand blast all the components and then......, i would like some feedback on what all you fellow dropmember guys did, any help would be great thanks, daniel.
Re: what to paint the dropmember with?
go with any industrial paint...
ive heard really good things about por-15, ive never used it personally but i havent heard anything bad about it
I know you said no powder-coating because of maintenance. What color were you thinking?
Black satin powder coat can be easily be touched up w/Krylon 'industrial' satin-blk or VHT epoxy satin-blk (both in rattle cans). N2billet had a frame PC'd & then changed direction to install F/R Dropmembers which required cutting into that fresh PC. When it was all said & done, if you didn't know where the frame was touched up, you didn't know it was touched up. That's why I like satin blk PC. It's an ultra strong foundation that can be touched up w/rattle cans if necessary in the future. No, it won't be as strong as the PC, but it will keep things looking uniform.
POR-15 would be great...it is very easy to apply with just a brush and once it dries, it looks like you sprayed it on there. Great product in my opinion....
I used Rustoleum Hammertone paint. Looks kinda like powercoat, and easy to touch up.
Por 15's durability blows away powder coating.
does por 15 work on parts that are sandblasted?
low n' slo
![]() Join Date: Mar 2009
i always thought por 15 really bites on to rusted areas...and not so great on bare metal...?
never personally used it but i thought i read that somewhere...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
One day.....
POR 15 sticks to anything. I would recommend it like the above post states, brush it on, make sure theres no dust and it will give you a high gloss shine like if you sprayed it on. If I was doing my frame, that's what i would use.
DZL1. |
Under Construction
if you go the por - 15 route, make sure you use the metal prep, then coat with por-15. you will want to topcoat if anything will be exposed to the sun as por-15 has no UV inhibitors....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
///Relaxed Atmosphere
i used por15 of mine dropmember and fraem parts. just make sure you metal prep all the sandlasted area's withe por15 metal prep solution and you wont have any problems.
Jeff
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
#13 |
I used this.. www.nomorerust.com get the UV stable kit AG111 kit and use a foam brush... this stuff is very tough but don't get it on your hands!!! it took a week to wear off once dry
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-26-2010 at 10:50 AM. |
#14 |
I would give it a coat of epoxy primer to seal it up and ensure that any chips don't result in rust creep. Then coat with something pliable to resist chipping.
1968 LWB C20 / AC / Wood Bed |
#15 |
Registered Cruiser
I used a chassis paint form summit. Very nice and durable, semi gloss. Easy to mix. You can brush it on or spray it on. I brushed it on and didn't like the brush strokes, so wet sanded smooth and sprayed it. Looks awesome!! I think it's like $50 or $60 a quart, but covers about 80 sq ft or so.
Check it out... http://www.summitracing.com/parts/SUM-CSUMUP501/ |
#16 |
this is great info as im wondering the same question. thans guys!
#17 | |
This is the glossy but they make a stin too...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-26-2010 at 06:11 PM. |
#18 |
I prefer Eastwoods rust encapsulator over por15. Its not a glossy finish, but I have had better luck with it...no metal ready (which is muratic acid) and it covers well.
#19 | |
Any pictures of the final product? |
#20 |
Registered Cruiser
#21 |
![]() Join Date: Jul 2009
Hey MSGross, your frame looks great!!! Especially after looking at the before pics
![]() Oh and Nice rotisserie...Where did you get that? Last edited by nlped; 04-30-2010 at 10:31 AM. |
#22 |
Registered Cruiser
#23 |
looks pretty good to me!!
