04-25-2010, 02:17 AM | #1 |
67 swb ls swap
I realize there are a lot of questions on the ls swaps, but i have some questions, i am putting a 6.0 4l80 into my 67. It is out of a 2000 chev, has iron heads, got the stock wire harness/pcm/fuse box with it. Am i better off taking out the big fuse box? Any input on wiring in 2 pcm controlled fans? Any input on the instrument cluster to work, or get a really expensive digital cluster? how about running fuel to it with regulator? I think im gonna put a fuel cell in it with walboro 255, but how to regulate it? And my buddy is doing the same swap into his s10 we will be getting the software to tune the pcm. Any info would help, thank you
04-25-2010, 08:46 AM | #2 |
Re: 67 swb ls swap
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
http://67-72chevytrucks.com/vboard/s...d.php?t=195643 http://67-72chevytrucks.com/vboard/s...d.php?t=269754 http://67-72chevytrucks.com/vboard/s...d.php?t=342165
R.I.P. Killer 71 10/26/07 |
04-26-2010, 09:06 PM | #3 |
Re: 67 swb ls swap
anyone else have any recommendations?
04-26-2010, 10:36 PM | #4 | |
Re: 67 swb ls swap
Since u have a 00 motor it should be regulated at the fuel rail if u have two fuel lines coming off the fuel rail which i think u should. Last edited by 68fixeruper; 04-26-2010 at 10:37 PM. |
04-26-2010, 10:52 PM | #5 |
Re: 67 swb ls swap
i do have a regulated rail, so that is simple. i purchased cpp perches today. and i believe i can use my stock trans xmember, just needs to be moved?
04-26-2010, 10:56 PM | #6 |
Re: 67 swb ls swap
the truck had a tbi 350 in it. the guy i purchased it from put a burban tank in the rear behind the rear diff in the frame rails. i know it only runs about 12 psi. so im prob gonna take that pos out, put a fuel cell in the back, and run a walboro w/high pressure lines.
04-26-2010, 11:30 PM | #7 |
Re: 67 swb ls swap
bueller... bueller....
04-27-2010, 12:04 AM | #8 |
Truck and auto performance nut
Re: 67 swb ls swap
I have a genIV LSx and I'm going with the MSD-6012 to read the crank/cam sensors and fire the coil packs, a carb and either Edelbrock or GMPP intake(if they'd finally release the LSX line) for the air/fuel with a low pressure (6-9psi?) A/C fuel pump...so I can't help.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-28-2010, 12:08 AM | #9 |
Re: 67 swb ls swap
i see, that should be a sweet ride anyway. i just took the harness off my engine, took the trans off the engine, waiting on my cpp perches/adapter plates so i can bolt her in and see how she fits. then ill line up my 4l80 and see where i have to mount the xmember and bolt it in. then to figure out wiring. I printed off all my diagrams from alldata at work, should make things easier
04-28-2010, 01:46 AM | #10 | |
Has more rust than truck...
Re: 67 swb ls swap
04-28-2010, 01:54 AM | #11 |
Re: 67 swb ls swap
I used this fuse block (top one) for mine and did away with the big factory fuse block (too big)
http://www.currentperformance.com/Ac...iring_acc.html I modified my stock engine harness. It wasn't that difficult to do if you know how to read a wiring diagram. There is a great thread that contains TONS of info....this will answer most of your questions http://67-72chevytrucks.com/vboard/s...d.php?t=377348 |
04-28-2010, 03:18 AM | #12 |
fan of "Butters" Stotch
Re: 67 swb ls swap
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
04-29-2010, 12:06 AM | #13 |
Re: 67 swb ls swap
[QUOTE=Ackattack;3945326]I used this fuse block (top one) for mine and did away with the big factory fuse block (too big)
K i saw that in a thread and i believe i am going to do the same. I went to school for hvac in the airforce and thats all they did was teach us how to read diagrams for like 3 weeks straight 8 hours a day, so i have that down well. i also printed off the engine management harness wiring diagrams at work. What circuits did u pull out ex(air conditioning.. etc)? and did you have to add anything to it? where do you connect your data link to on the harness, does it tap directly into the pcm? thank you |
04-29-2010, 12:19 AM | #14 |
Re: 67 swb ls swap
your harness will have a data port...or you have to wire one
04-29-2010, 03:10 AM | #15 |
Always wrenching!!
Re: 67 swb ls swap
You can check out my build also for some more info. link in sig
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
04-29-2010, 05:36 PM | #16 |
Re: 67 swb ls swap
it did not come with a dlp.. so i will have to wire one hehe
04-30-2010, 12:29 AM | #17 |
Always wrenching!!
Re: 67 swb ls swap
the dlp is part of the dash board wire, not part of the engine harness. pick n pull or wrecking yard is an easy find.
