Old 02-09-2003, 08:53 PM   #1
Stainless
Olds 455 in a '70 C10
Hey all.... with some great advice from Crazy Longhorn... I talked myself into buying an Olds 455 with a TH400 transmission to put into my 1970 C10.... I have heard that I can use engine mounts from a V-8 olds.... or chevy BB.... What about the tranny crossmember? The chevy bolts to the bellhousing.... but the olds is on the tail of the tranny.... Anyone mess with that before? I have swapped motors before, but only same parts. Any advice for a newb would be appreciated!!!
~Sean
Stainless is offline   Reply With Quote
Old 02-09-2003, 09:53 PM   #2
crazy longhorn
Fabricate till you "puke"
You need the auto trans crossmember for the pickup(it mounts under the tail of the trans). the bell mount stick crossmember can be removed from the frame. As far as the mounts/stands/brackets, a late 70's truck with a 5.7 deisel was the donor on my swap. the eng mounts themselves will be the same as a late 60's-mid 70's cutlass(napa crossed them for me). the Chevy eng mounts wont bolt to the Olds block, but you might use the 72 BB stands to get the nose height down a little on the Olds....if you can find a set. if the truck deisel brackets arent available, you can substitute a set of olds car brackets to mount to the stands, but need to look for a set with a short height, & plan on welding them to the frame stands. That BB olds is a powerhouse, & right at home in a 4000 lb truck.........good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-09-2003, 11:03 PM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
CrazyL hit the nail right on the head. The 5.7 diesel motor mounts would be the best way to go. I put a 350 olds in a 49 ford F-3. I fabbed up my mounts because I didn't have any olds mounts out of the car. The one's I built are way stouter than the factory mounts anyway.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 02-09-2003, 11:05 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I have an automatic cross member from a 72 $50 plus shipping
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
