Old 04-25-2010, 05:05 PM   #1
67mbsc
Which Starter Bolts Do I Need?
I have a 1968 C-10 with a manual trans, and a small block engine. The starter has a cast iron nose, and the mounting bolts go thru the nose, into the bellhousing, and NOT the block.
My question is, where can I find the correct bolts, as each of them is different. The bottom one will have a large shoulder, the middle one has a smaller shoulder, and the top, that bolts thru the bellhousing, into the starter, may not have any shoulder!
I have NO bolts right now, had my local dealer look, they even called the factory, and nothing came out!
I want to keep the starter that I have it's new, and I don't have any block mount starters right now!
The hole for the bottom bolt is almost 7/16". Is there a bushing for this?
Thanks,
2% Forever!!!!!!
67mbsc is offline   Reply With Quote
Old 04-25-2010, 08:50 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Which Starter Bolts Do I Need?
They are all 3/8 bolts with no bushings. The starter nosecone indexes into the bellhousing for alignment.
I just stick a pencil or screwdriver in the holes to find the needed length and install appropriate length 3/8 bolts from my bolt can or new.
Also, I agree with you. The cast iron nosecone starters are outstanding units. I like the way the mount as opposed to the type that bolt to the block.
Old 04-27-2010, 08:19 AM   #3
67mbsc
without a serious shoulder, the bottom bolt is really worthless towards lining anything up! Will the one top bolt really put the starter in it's place? The middle one, with a normal knurling, would work for the middle hole.
2% Forever!!!!!!
Old 04-27-2010, 08:27 AM   #4
Tx Firefighter
The raised lip around the starter nose housing indexes into the bellhousing and does the locating.
