Old 04-25-2010, 07:33 PM   #1
Neal Molder
The Black Pearl
68 3/4 ton torque specs?
Can anyone enlighten me as to what the front end torque is on upper and lower ball joints for a c 20 is?
Neal Molder is offline   Reply With Quote
Old 04-25-2010, 07:54 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 68 3/4 ton torque specs?
'67 manual says 120 ft-lbs for upper ball joint stud and 215 ft-lbs for lower ball joint studs for a C20. I doubt it changed for '68.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-27-2010, 09:21 PM   #3
Neal Molder
The Black Pearl
Thanks Shaky! Greatly appreciated!
Old 04-27-2010, 09:34 PM   #4
vectorit
What?
vectorit's Avatar
You should really get one of these service manuals.
Call these guys to get one.
http://www.faxonautoliterature.com/home_one.cfm
Not being snide, just that this book will be your friend as long as you own your 68.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-28-2010, 07:55 AM   #5
crakarjax
crakarjax's Avatar
What does the chassis service manual cover? IE, if I have a 68 with 72 suspension, would this still be applicable?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-28-2010, 08:36 AM   #6
cdowns
cdowns's Avatar
most stuff will b good for you// it's well worth the small amt of the investment
most board vendors can supply you with one cheap
its a great way to learn the proper way to do things/// engine trannny brakes rear , steering, loads of usefull info and specs
ALOT better value for your money than magazines
