04-25-2010, 07:52 PM | #1 |
Retired Air Force Veteran
Gauge Cluster with Tach
Over the weekend, I picked up a Gauge Cluster with a Tach. The lens reads 5000 rpm max. Are there differences between the OEM Tach's. Were they all for 8 Cylinders or did the 6 cylinders offer a Tach also.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
04-25-2010, 08:00 PM | #2 |
Nothing to see here.....
Re: Gauge Cluster with Tach
iirc, both the 6 and 8 cylinder tachs went to 5,000 - the difference is internal. take a look on the back of the tach tin. in most cases, the factory stamped "6 CYLINDER" or "8 CYLINDER" on the back. the 6 cylinder tachs are a bit harder to find.
fyi, the diesel tachs registered up to 4,000.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 04-25-2010 at 08:02 PM. |
04-25-2010, 08:04 PM | #3 |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-25-2010, 08:12 PM | #4 |
thanks guys. i just looked and its a bit dirty and the only stamps i see are those being 12v and coil. i'll look again tomorrow after i get things all cleaned up.
04-25-2010, 08:14 PM | #5 |
Tot Roddin'
BTW, congrats on the buy Harry!
04-25-2010, 08:21 PM | #6 |
Thanks Nate, Ipicked it up at Carlisle on Friday Afternoon. The tach and the other gauges are fine, the rest of the cluster needs some work. Im going to get a new bezel, lens and I bead blasted the tins today. Should look nice when it's done. I've been looking for a tach cluster for a while....man I love going to swap meets
