04-25-2010, 08:48 PM | #1 |
Another what is this thread...help me,plz
This is under dash, don't know where it goes. Was messing around under there trying to clean it up and wondering why my alarm is not working and found this plug and have no idea where it goes.
thx all. It's coming together slowly. Got the vent windows out to replace the felt and seals.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
04-25-2010, 09:56 PM | #2 |
right below above average joe
Re: Another what is this thread...help me,plz
looks kinda like a vats harness but i'm pretty sure these old trucks didn't have that...
i flush the of weakness with mushroom clouds at hand '95 short bed x cab c1500... just another old truck someone else beat up, abused, hacked and didnt respect... my turn to turn it into a beat up old truck into a beat up and reliable pleasure to drive... them- "when you gonna put an exhaust on that thing?" me- "what do you mean? The exhaust comes all the way to the bumber and sounds great!" them- "straight pipes isnt an exhaust man..." me- "meh... who needs a fancy muffler when you've got straight pipes? its got a cat, doesnt resonate, and I like how it sounds, and to be perfectly honest, it makes me behave myself when I'm out and about!" ^^^ favorite conversation about my truck to date |
04-26-2010, 12:02 AM | #3 |
Location: Where I come from, it's cornbread and chicken...
it's probably power for your alarm...looks like red/pink which should be switch power, yellow which should be constant power, and black which should be ground...I would look up under there for some kind of box and see if you can see where it plugs into...
04-26-2010, 12:34 AM | #4 |
its not for alarm, all that is connected fine. It is a factory connector...just can't remember what it goes to.
I just took out the alarm box, it's getting power, and my shock sensor is working...I'll mess with it some more later. thx. ps pink/black, black,yellow wires...
04-26-2010, 09:02 AM | #5 |
One shot, one kill.
First thing, what year we looking at? Does it have cruise control or did it have cruise? I can't really see the end of the terminal to well, but it looks like the VSS sensor connection OR, the cruise switch connector. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
04-26-2010, 04:38 PM | #6 |
its an 86 and yes it had cruise.
Whats weird is I looked at my old cluster and it still has the green cruise control pigtail connector(flat blade type)... hmmm
04-26-2010, 05:01 PM | #7 |
It looks like it is for the stock radio power, ground and constant.
04-26-2010, 05:31 PM | #8 |
04-26-2010, 05:38 PM | #9 |
Getting Old; Going Broke
No, fairly certain it is not a radio plug. Not sure what this radio is out of, but it was in a 81-87 when we pulled it at the bone yard.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
04-26-2010, 05:41 PM | #10 |
All I know of is when I put a radio in my 1978 that is what the radio hot ground and constant plug looked like and there was a seperate plug for the speaker wires.
04-26-2010, 08:05 PM | #11 |
Starter interrupt for a manual?
Fasten seatbelt buzzer?
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
04-26-2010, 08:30 PM | #12 |
might be factory radio....my wiring diagram is not giving me much...
thx all.
04-27-2010, 01:59 PM | #13 |
Get a VOM, hook one lead to a known ground, stick the other end in the sockets one at a time and see what the VOM says when set to VDC. There should be a constant hot, switched hot, and a ground...the ground will have to be tested on the VOM at the impedance setting.
04-27-2010, 02:26 PM | #14 |
Next project: 1970 K10
According to my Haynes, it's probably for the VSS. Black, yellow and pink/black. Plugs in to VSS on the old cluster?
And according to this schematic, it is the VSS as well, only brown instead of black. Lower left of the drawing. I seem to remember removing that one during my swap. Sorry for the BIG pic!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-27-2010 at 02:28 PM. |
04-29-2010, 07:27 PM | #15 |
www.73-87chevytrucks.com
Looks like My haynes manual Bob....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-29-2010, 07:33 PM | #16 |
It tis, my friend! That is from a Haynes manual? Looks very different than mine. Mine's not at all as detailed as the ones you have.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-29-2010 at 07:35 PM. |
04-29-2010, 08:39 PM | #17 |
glock, thx a ton.
That really helped. John
05-01-2010, 08:51 PM | #18 |
BAD BOW-Silverado XST
Normally, you can find plugs not being used. Wiring harnesses were generic for every option available. Check it for power. You can use the plug to add options.
