![]() Join Date: Jan 2010
Time for new gauges! Before new engine.
I have a '85 Silverado with the factory gauges,and want to upgrade to a newer style gauges that will fit in the original holes in the dash. Would like something with easy hook up and be accurate.
Any recommandations? Thanks Coater |
Next project: 1970 K10
Re: Time for new gauges! Before new engine.
Anyone?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
I have been contemplating an Auto Mete gauge set up from Summit. Looking @ 2 5/8" gauges for the fuel, oil pressure, volt/ammeter, water and 5" gauges for the Speedo and the tach. Should run about $ 300-400 dollars depending on the model. They sell the 2 5/8" set up (3 gauges) for about $ 45.00. That tach and the speedo is where all of the money goes
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
Do those set on top of the gauge panel or recess in like the stock ones?
Slots go on anything!
You can do them either way.
http://www.73-87.com/7387garage/inte...s_recessed.htm or http://www.73-87.com/7387garage/inte...ge_surface.htm
1974 Jimmy- 5.3/4L80e/NP241 |
Thank You so much!
heres mine and i think this is what your looking for. i went with all auto-meter pro-comps the oil and water are liquid filled and i ended up changeing the speedo to a electronic because you can program it to any tire size and if you change tire size you just reprogram it.
87 gmc with a 383,6 in lift,everything new inside and out. |
Usually I don't like the gauges mounted on the front side of the bezel, but your setup looks really good with the wood grain. Nice job!
I agree! It looks nice with the wood grain.I also have the factory clock in my dash. Do they make a clock also?
auto-meter does just, not in that series. i think sport-comp series does offer one.
