I Got it BAD!
Factory Brake Booster with Disc
Anybody have any experience using a factory 66 power brake booster with Disc/Drum brakes? I Bought the CPP grandslam drop kit with booster and master cylinder. It fit's horrible. Once everything is bolted up you still have to somehow seal the original 2"hole the mastercylinder used to fill. The new CPP booster and dust boot sit away from the firewall and just allow weather, heat, fumes and noise to enter the cab. I know I could probably buy a boot to seal the firewall but the CPP kit just seems like crap.
So my question is. Can I use my factory power booster and just put a disc master cylinder on it? i'm concerned about the bore and stroke needed to make everything work. Anybody done this?
Build Thread: http://www.chevyguys.com |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Factory Brake Booster with Disc
I haven't installed a disc/drum master on an original booster, but I do have an alternative if you're interested. There is a link in my sig.
A dual chamber master cylinder can be installed on the factory power brake booster, along with a porportioning valve, to compensate for disk/drum brake system, without modification.
I Got it BAD!
Thanks Tony! I'll give it a try and see how it goes...
i have a factory booster on my truck works great. i used a master cyl for a 72 and portioning valve off the same with disc and drum. no problems at all.
i think you can bolt on a 1971-72 chevy pickup master cylinder with manual brakes on to the factory 63-66 power brake booster....
#7 | |
I know first post. ![]() |
When I put on my CPP booster and master, I found the boot had to be turned a specific way to fit the hole, which required taking off the master, and loosening the brake booster brackets enough to get the pressure off the boot, so it can be moved around.
The boot has a bend to it, and when I put it on, there was a gap between the hole and boot. |
You don't have to take off the master cylinder, but it makes it lighter and much easier to support and move around by yourself.
#10 | |
I Got it BAD!
1. The bracket does not line up to any of the factory holes (5) for the factory brake booster. 2. The boot does not seal the firewall, it only acts as a dust boot for the booster. Honestly, I could just modify the firewall, fill the holes and put another dust boot in to keep weather and heat from the engine out of the cab. However, I don't want to do that as I have no desire to modify a factory low hump, big back window, Air conditioning cab!! This is why I purchased the kit from CPP as it was a "bolt-on" kit!! Here are a few pic's of my situation... Which by the way I am just going to use a factory booster with a 71-72 Master as others suggested.
Build Thread: http://www.chevyguys.com Last edited by chevyguys; 05-08-2010 at 07:01 PM. |
#11 | |
I Got it BAD!
Will never buy anything from CPP again!
Build Thread: http://www.chevyguys.com Last edited by chevyguys; 05-08-2010 at 07:00 PM. Reason: ooops misspelled the company |
That's different looking, I mean the boot, yours has a flex type boot.
#13 | |
Thanks for the pics. |
#14 | |
I Got it BAD!
Yes they do but you have to call them.. they don't have a generic kit on their website.. They tailor it to your truck and have many different options. The cost comes out to about 100.00 more than CPP's kit but you get quality parts such as the bearings, rotors and calipers. I helped my buddy put his together and everything fit excellent.
#15 |
Thanks again, I'll be getting in touch with them on Monday.
#16 |
Ok i read this and i appologize for the confusion we have installed this booster for years on 63-66 Chevy trucks and we have actual tech articles from the magazines on our website to support the installation. You do need to drill a couple holes in the firewall as indicated in the instructions let me post some pics. Thanks Jeff.
#17 |
http://www.classicperform.com/tech_a...topBraking.htm
Here is a link to a National magazine Installation we did on a 1965 Chevy Truck. |
#18 |
I Got it BAD!
Thank you for the information. I am aware of the documentation. My concern is with the fact that there are already 5 holes in the firewall for the master/booster assembly. It seems a shame to have to drill two more. How about a bracket for the booster that allows the purchaser to use the existing holes in the firewall?
Also, since the dust boot does not seal the firewall how is that handled? Thanks for responding here in the forum. I'm sure this information will benefit many members.
Build Thread: http://www.chevyguys.com Last edited by chevyguys; 05-11-2010 at 11:30 AM. Reason: Additional information provided |
#19 | |
#20 | |
I Got it BAD!
#21 |
#22 |
Subscribed, since I've bought a cpp master & booster. (I have the same problem with the boot)
#23 |
#24 |
PM sent with email.
#25 |
I took some pics of mine
![]() ![]() A shot of the underside of the brackets and seal ![]() |
