04-26-2010, 08:33 AM | #1 |
Air Tank Installation Pictures
I have a 72 Chevy SWB and looking at location options for my tank. I have a stainless steel fuel tank in the rear. so between the rails in the back is out. I haven't decided to run two tanks or one. This is my first airbag install so any help and pictures will be appreciated
Mike
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension |
04-26-2010, 12:33 PM | #2 |
Re: Air Tank Installation Pictures
Bump. Also looking for ideas gas tank in the rear also.
04-27-2010, 07:24 AM | #3 |
Was considering mounting 3 gal tanks one on each side to a plate welded to the cross sills on the bottom side of the bed floor in front of the rear tires. What do the experts think
04-27-2010, 11:45 AM | #4 |
67cheby
heres mine
04-27-2010, 01:15 PM | #5 |
I am wrapping up may bag install this weekend with a front end rebuild.
I mounted two three gallon tanks under the bed, in front of the rear tires. i mounted them directly to the frame. i will try to get pics. |
04-27-2010, 04:14 PM | #6 |
I mounted my to the back cross plate behind my blazer tank, but then, mines a longbed
1967custom |
04-27-2010, 05:36 PM | #7 |
yes with my rear tank there in no room at all for it.
04-27-2010, 05:38 PM | #8 |
Thanks I would like to see your tank and compressor set up. I am new to this and am looking for any and all ideas.
04-27-2010, 07:44 PM | #9 |
these pic's suck but it was all i could get real quick. i am eventually going to make myself a build thread when i get the bags done this weekend.
this first is the compressor in the back passenger side corner, from there the lines go to the passenger side tank, then over to the drivers side tank, and then back to the box in the back. i have installed an accuair control system, so everything is in the black box. i am running hard lines on the compressor/tank side and plastic lines on the bag side for now. i will eventually go to all hard lines. I have all lines, electrical, and height sensors installed, but i have yet to turn the bag control system on or hook up the rear bags, they are manual fill for now. the system has been holding 120 psi for a few days now. notice the schraders, i went that route in case of a compressor failure and they also double as moiture drains. you cant see it, but on the passenger side tank there is a quick disconnect so i can hook up an air line and run air tools or fill tires. like i said i am rebuilding the front end and installing the front bags in a few days. i just need to put a fuse in the new fuse block after i hook up all four bags and (fingers crossed) it will come to life. Last edited by dznucks; 04-27-2010 at 08:42 PM. |
04-27-2010, 07:46 PM | #10 |
more. hope this helps. this is my first bag install. i am by no means an expert so i am sure the experts will have alot to critique. but this is how i'm rollin'.
04-28-2010, 07:16 AM | #11 |
This is definitely helping, getting some good idea.
