Old 04-26-2010, 09:10 AM   #1
Ynotnow817
Ynotnow817's Avatar
taking out 350
I have a '75 burb. Do I have to remove the hood to take out the 350? Also any other tips would be appreciated. I am a total rookie.
Ynotnow817 is offline   Reply With Quote
Old 04-26-2010, 09:21 AM   #2
Jonboy
Slots go on anything!
Re: taking out 350
That will help out a lot. Depending on what you are planning on using, you can unbolt the A/C and power steering from the engine to remove it, then come back for them later. I am guessing you are stripping it as a donor for your pickup? If that is the case, it may be faster and easier to remove the front end, and pull the engine and transmission as a unit.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-26-2010, 09:23 AM   #3
Ynotnow817
Ynotnow817's Avatar
Re: taking out 350
That is the plan(donor). So remove the front end first?
Old 04-26-2010, 09:32 AM   #4
DPowers
DPowers's Avatar
Re: taking out 350
Take pictures at different angles before you start and save ALL the bolts.
DPowers is offline   Reply With Quote
Old 04-26-2010, 09:37 AM   #5
Ynotnow817
Ynotnow817's Avatar
Re: taking out 350
Will do thanks.
Old 04-26-2010, 10:25 AM   #6
Jonboy
Re: taking out 350
If you are planning on parting out the 'burb, and don't care how it goes back together, I would pull the clip, just to get it out of the way. That will make it easier to get to the suspension I am assuming you will use, too. I like the extra room to work, too.
Old 04-26-2010, 11:53 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: taking out 350
you dont tell us alot here but i agree with johnboy pull the clip if youre scrapping the burb as it goes easier and if you want to make it easy pull the trans with it.
If youre not pulling the trans too and this is a motor swap, make sure you remember to get the torque convertor bolts as the first swap i did i forgot them
You have to pull the radiator and at the very least the hood.
I also find it a heck of alot easier to leave the exhaust manifolds in as the bolts that hold them onto the block are alot easier to break loose and unbolt than the flange bolts
like the other poster said make sure you label things with masking tape and labelled sandwich bags with the bolts are another good idea
also the stupidest advice can be the best advice.. make sure the truck is properly supported and blocked before you start this job
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-26-2010, 01:41 PM   #8
Ynotnow817
Ynotnow817's Avatar
Re: taking out 350
Yes I am scrapping it. thanks for the good advice.
