No brake pedal
My '67 Long Fleet had been sitting at my parents' house for about 9 years when i decided to go get it and put it back on the road. The brakes would pump up good on it but would gradually fade and the pedal would drop the longer you sat stopped at a light. There was no fluid loss, so i chalked this up to a failing master cylinder. I got a new one, bench bled it and installed it. Tried to bleed the brakes but couldn't get any pedal back. Since then I have installed all new shoes, new wheel cylinders, new flex hoses, replaced most of the hard lines,replaced and adjusted the old frozen screw adjusters, and even went and got another new master cylinder and installed it. Still cannot get any pedal feel. Could the prop valve be bad and cause this. Every bleeder yields fluid and no bubbles when opened. Truck is all drum and no power booster.
![]() Join Date: Jan 2007
Re: No brake pedal
**just saw - no power brakes**
if you have power brakes - check the vacuum line from the booster to the rear of the carb. It might need replaced. If it is that old - it may be collapsing on itself and taking the firm pedal with it. I had this on my 70 LWB project. Rebuilt the brakes and then found it to be the vacuum line causing them to be soft. Last edited by lks dcvn; 04-26-2010 at 10:39 AM. |
#3 | |
Re: No brake pedal
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 04-27-2010 at 10:33 AM. |
its all about the +6 inches
Re: No brake pedal
i would start with adjusting the shoes out
