04-26-2010, 05:30 PM | #1 |
Torque
OK fellas, I found out a very frustrating fact about these trucks. Even though you have all the service manuals, assembly manuals and even the Haynes manual some things you still can't find. I need the torque for the rear U bolts attatching the axle to the leaf springs. Also is there a procedure for tightening them I don't want to break the saddles they are not available in the catalogs. The frame is a 72 GMC K2500 has a Dana 60 and I removed all the extra leafs that the previous owner installed. Now it's bone stock. The Haynes manual only has the procedure for the 73 and up leafs not the one I need.
Thanks Navysnipe |
04-26-2010, 06:11 PM | #2 |
Re: Torque
in my 73 manual it has the torque for the ubolts on the rear axel as 140ftlbs // cant imagine it's much different for other years
as far as technique , i was trained that you loose tighten all 4 so the same amt of thread is visable then slowly in 3 or 4 steps tighten diagonally opposing corners till you get to the final torque
04-26-2010, 06:35 PM | #3 |
My Carbon Footprint
Re: Torque
The torque I run is "tight" on things like that!
04-26-2010, 07:11 PM | #4 | |
Re: Torque
Looks to me like cdowns is right on it.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
04-26-2010, 07:40 PM | #5 |
Re: Torque
my manual says torque to 90 ft lbs then release jack, when weight is on suspension tighten up to 140ft lbs says in a diagonal pattern too.
