Old 02-09-2003, 11:40 PM   #1
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
proper placement
I have question about a couple things. I have a sbc in the I6 position I installed a set of headers that a few other pepole said the collectors were paralell with the frame on theirs. I was wondering if the engines angle is difrent in the v8 position as opposed to the I6 position I know it will be about 3 farther forwards.
GMC JUNKIE TOO is offline   Reply With Quote
Old 02-10-2003, 12:20 AM   #2
crazy longhorn
Fabricate till you "puke"
there isnt a noticeable diffference in the height/angle in I6 vs v8 position......that i could find anyway. I have hooker comps on mine , & the collectors are parallel with ea other, & show approx 2 1/4" below the frame. I dont have any shots of the bottom of the frame, but a couple eng shots. here is the link .... http://community.webshots.com/user/hotrodhorn I would say the Hookers are pretty much parallel with the frame. What headers are you running? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-10-2003, 12:41 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here is a belly shot of mine with Super Comps with the engine in the proper location. (small block)
Old 02-10-2003, 12:50 AM   #4
crazy longhorn
thats pretty much how my Comps hang in I 6 position....just a little farther to the rear....crazyL
Old 02-10-2003, 12:53 AM   #5
GMC JUNKIE TOO
Thank guys I will leave it where it is.
