Old 04-26-2010, 09:06 PM   #1
scott72
scott72's Avatar
Question Edelbrock Performer Series for 350
I am looking at upgrading my intake and carb next. I never had any problems with Edelbrock in the past. It has been years since I put these on my Nova, but I am guessing at:
Non-EGR, Manual Choke on carb
non-egr on intake?
Anyone think this looks good, or offer some advice?
scott72 is offline   Reply With Quote
Old 04-26-2010, 09:09 PM   #2
hugger6933
Re: Edelbrock Performer Series for 350
I would get the electric choke model 600. Set that thing up and drive the wheels off and don't worry about it. Jim
hugger6933 is offline   Reply With Quote
Old 04-26-2010, 10:54 PM   #3
tremman78
tremman78's Avatar
i would get the electric choke model 600. Set that thing up and drive the wheels off and don't worry about it. Jim
x2
tremman78 is offline   Reply With Quote
Old 04-26-2010, 11:50 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
X3, #1406
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-27-2010, 09:28 PM   #5
scott72
scott72's Avatar
Cool, thanks for the help.
Old 04-28-2010, 11:33 PM   #6
AustinScott
AustinScott's Avatar
I currently run a #1406 on my 327.... it runs strong now that I made a rod change ($9.00) and about 5 minutes.. It was a bit lean from the factory for my 327, but after a simple rod change its like a completely different beast....
I'm also running a Edel...RPM airgap intake (7516) vortec style... its a screamer!!!
#1406 is a "safe" and simple bet.. if you are on these forums asking for carb advise....
AustinScott is offline   Reply With Quote
Old 04-28-2010, 11:38 PM   #7
leddzepp
Moderator
leddzepp's Avatar
x4 Edelbrock 1406
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-29-2010, 02:03 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a Carter 9635 AFB on my '71 Jimmy. It's the equivalent of the Edel 1405, 600CFM Manual choke on a 350. I also have an Edelbrock 1404 500 CFM on the 292 L6 in my '68 Stepside. Great carbs and they are simple to tune.
Flatlanders don't understand how radical changes in density/altitude can affect carb tuning. I used to ski and was active in mountain rescue. I took my trucks everywhere. I will not use anything but a manual choke. If you keep your truck at one elevation for its whole operational life, you can hope an automatic choke will make the right decision for you. I found they usually do the wrong thing at the wrong time. With a manual choke you just pull the knob if you want a choke or leave it alone if you don't.
Old 04-29-2010, 07:20 AM   #9
LMN8UR
LMN8UR's Avatar
x5 Edelbrock 1406, I put 150k+ on mine with no worries or maintenance!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 04-29-2010, 11:47 AM   #10
'72customdeluxe
If you're asking for opinions I'd say a '76+ quadrajet, a good tuning book, and a spreadbore performer manifold. Mine has no egr but has provisions for my hot air choke.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-29-2010, 11:53 AM   #11
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Not sure what the difference is with the 1406 and the 1806 beyond the 600 vs. 650 cfm rating. But thats the one I have on order and should do better than the Holley 600 cfm I currently have (and is leaking fuel btw).
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-29-2010, 12:03 PM   #12
'72customdeluxe
The avs series carbs (that 650) have a screw adjustable secondary opening spring. Might be some other differences as well
Old 04-30-2010, 02:33 AM   #13
'68OrangeSunshine
Mopar used to use AVS Carters on their big block 440s in the '70s.
One difference between the old schule Carter and the next generation EDL AVS <<THUNDEROR>> is that the step-up rods on the old AVS had 3 steps -one for mid-range settings for HD/towing apps-- and the Thunder has only 2, same as the AFB /Performer.
You can't get the 3-step rods any more. Too bad, but we all have to work with what we got.
Old 04-30-2010, 04:54 AM   #14
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Exactly!
I've got a quadrajet from a 79 corvette on my '71 350 truck and it runs like a top.
perfect!
beebster is offline   Reply With Quote
