04-26-2010, 09:08 PM | #1 |
Instrument panel question...
How do i get my instrument panel off? itook out the screws but it stil felt hung around the washer knob and light knob. I figured they had to come off but how?
71 C-15 350 three speed. |
04-26-2010, 09:19 PM | #2 |
Re: Instrument panel question...
Reach behind the cluster and on the switchyou will find a small metal button push on that and you can then pull out the knobs. Jim
04-26-2010, 09:19 PM | #3 |
Nothing to see here.....
the chrome washer trim screws off. try a pair of needle nose pliers in the two holes in the washer and unscrew to the left.
the light knob must be removed. 1st, pull the light switch all the way out. then fish you hand up under the dash to the light switch assembly. you'll feel a button on the top rear of the assembly. push this button down, and pull the light knob out. you should be able to remove the panel if you main harness is disconnected and the oil pressure hard wiring is disconnected. if you have a tach or vac gauge, make sure you disconnect those as well.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
