Old 04-26-2010, 10:12 PM   #1
storked82
storked82's Avatar
Need hood prop ideas for fiberglass hood
Hello Guys
Do any of you guys have pictures of hood props for a fiberglass hood?
Im useing pvc pipe now but it looks bad in my opion when I go to cars shows
Im looking for something better any ideas ? plz if you have pictures that would be a great help or any hows tos ect
Thanks for the help and advice
Jeff Main
storked82 is offline   Reply With Quote
Old 04-26-2010, 11:06 PM   #2
tdiffee
tdiffee's Avatar
Re: Need hood prop ideas for fiberglass hood
I used a hood prop from an s-10 on my old 2000 tahoe limited when I put a fiberglass cowl on it. If you order the prop and the holder it won't get in the way and it looks like it is supposed to be there. But it was not a show truck it was my dd.
tdiffee is offline   Reply With Quote
Old 04-26-2010, 11:12 PM   #3
mongoose
mongoose's Avatar
have you though of using gas struts instead of the springs?..
i've even seen someone drill a hole in the hinges and stick a pin in it to keep it proped up..
just a couple other ideas.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-26-2010, 11:25 PM   #4
tdiffee
tdiffee's Avatar
I think the pin idea would look nice at shows and would be easier and cheaper!!
Old 04-26-2010, 11:40 PM   #5
ANDREW
Old camshaft hahah think id be cool
ANDREW is offline   Reply With Quote
Old 04-27-2010, 12:31 AM   #6
78 Chevyrado
I've seen a couple of people do that at the shows... Looked cool!
78 Chevyrado is offline   Reply With Quote
Old 04-27-2010, 09:38 AM   #7
OJOE
Crew Cut
OJOE's Avatar
i had a 4'' harwood hood on my 85 with factory springs, no problem
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 04-27-2010, 12:28 PM   #8
Restrorob
The One And Only !!!
Restrorob's Avatar
Think I'd be leery of all the weight of the hood stressing where the hinges mount ?!?!?
Check the pics link in my sig, You can see what happened to my 97 using a prop rod and what I did to do away with it.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-27-2010, 12:38 PM   #9
storked82
storked82's Avatar
Mongoose
Thats sounds like a good idea with the struts even the pin idea I wounder if anyone has picuters useing the struts ? The hood is on an 82 and im just woundering if the pins would work ?
Thanks for the advice guys
Jeff Main
Old 04-27-2010, 05:53 PM   #10
68 TT
Still plays with trucks
68 TT's Avatar
...i've even seen someone drill a hole in the hinges and stick a pin in it to keep it proped up..
I did that with my Chevelle. I used small 1/4" quick release pins through both hinges. It worked great and one person could do it. Down side is that everybody who might be working on your car needs to know about them. I had a couple people try to close the hood without pulling the pins. Cracked paint one time and cracked hood the second. This was a race weight hood so it probably cracked easier than a typical street bound hood would have. Maybe put some small "remove before flight" banners on them.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-27-2010, 09:47 PM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Electric linear actuators
"Nuff said"
EXCELLSIOR!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-27-2010, 11:46 PM   #12
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
hell thats kinda pricey too, but wonderful idea. 6' or 8" or stroke should be plenty
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
