![]() Join Date: Apr 2008
five or six speed
anyone do a five or six speed swap in there truck? looking for ideas on swapping out my nv3500 for something better.
Old Skool Club
![]() Join Date: Jun 2001
Re: five or six speed
Five-speeds were common. What are you looking for?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#3 | |
"Oh well, it's a driver."
I'm interested to see what kind of responses you get...ever since you were talking about it in your build thread I've been wishing I had a great big hurst cue ball coming out of my floorpan...
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
It's not a swap, but I have a factory 5-speed in my '91.
#5 | |
NV3500? Are you hard on it?
I have a NV3500 in my 90. For some reason it wants to be shifted slow or it will grind in 2nd and 3rd. If swapping from an automatic or changing the master and slave cylinders I highly recomend bleeding the system with a vacume pump.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
#7 | |
Might be.
Some things I've read say that the NV3500 didn't start until '92 or '93, but the previous years are still New Ventures and use the same housing.Quote:
well i have heard they are a weak trans and i have had two of them but they have had there problems. i want to know if anyone has swapped in a t5 o5 t56 or anything like that. anything that will hold up to 500 hp and tourque. i would hate to have to swap to and auto and waist a good clutch pedal!!
Old Skool Club
If that is the case, and if those transmissions were ever a GM-install behind a small block, it seems to me that it shouldn't be a big deal....well, sorta. Seems that before I could do that a whole pile of unobtanium would have to fall into my lap.....unobtanium = $$$.
Then, a driveshaft would probably be on the short list of "must-haves". But, ain't no biggee.
| Bookmarks |
