Old 04-26-2010, 11:46 PM   #1
hotrodrookie
hotrodrookie's Avatar
Bolt mounting Question...
Hi guys, this is kinda of a beginner question but when using bolts through a double shear situation, can you mount one side on the threads or do all the threads have to be on the outside and require the use of a washer?
Im mounting end bushings for my 4 link bars, I just dont like how there is so much thread sticking out as shown in the drawing( using a 5/8-18-4.5" grade 8 bolt)
Can I buy shorter bolts or do I need them full length so as to not damge the threads for any reason?
hotrodrookie is offline   Reply With Quote
Old 04-27-2010, 12:33 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Bolt mounting Question...
Obviously, having a bolt that is sized perfectly would be the best option. Check aircraft supply catalogs. Or a bolt specialty store. WagAero, as well as Fastenall and Grainger come to mind.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-27-2010, 09:40 PM   #3
hotrodrookie
Well, Im going off of standard sizes that I can buy from Fastenall. If I were to buy a 4" bolt, the threads would be seated in the hole.
Can somebody help me out?
Old 04-28-2010, 08:05 AM   #4
Turbo85GMC
Turbo85GMC's Avatar
In a critical application, you want the bolt long enough so that the full diameter protrudes through the other side. You should have just enough so that a washer will take up the slack but not enough that the nut bottoms out before fully clamping.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-28-2010, 08:29 AM   #5
Shane
Shane's Avatar
I agree with Turbo85GMC ... you would want the shear load on the "shoulder" of the fastener and not on the threads.
Here is an AWESOME pdf file that I have used for years on proper use of fasteners.
http://gltrs.grc.nasa.gov/reports/1990/RP-1228.pdf
Shane is offline   Reply With Quote
Old 04-28-2010, 09:01 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The fellows are right, you want the shoulder carrying the weight not the threads. I understand you're having trouble getting the exact length through your sources, so I'd run the 4.5 inch bolt and cut it shorter before running a 4 inch and having weight bearing down on the threads.
