LQ4 Swap, Performance Online or Stock Mounts
I am finally getting around to putting an LQ4 into my 68. I have the motor in using the stock 6 cyl perches and motor mounts. I like that it sits way back in the engine compartment, but dont like the stock mounts with the center hole in the mount.
Can i use the peformance online pedestals and keep the motor in the same location or will using them mean i have to move the motor forward to the sbc location?
Joe |
Re: LQ4 Swap, Performance Online or Stock Mounts
I ordered the ECE mounts. No more one-hole wonder for me!!!
There are good pictures of the mounts here: http://www.pro-touring.com/forum/sho...d.php?p=447787 Last edited by Jim_PA; 04-27-2010 at 09:58 AM. |
Do they keep the Motor in the rear most hlocation?
Are you running manifolds ? I see that prothan has a 7-519-BL. Mount in the originalstyle t should be stronger.
Joe |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I bought some of the CPP perches ( 6372MPT) and ended up not using them because I went with the tubular mounts from POL. The CPP units set the engine to the front and it didnt work for me, I still have the CPP mounts if you would be interested.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#5 | |
#6 | |
I don't have them yet, so I can't give you any more details, but it appears to use the front and rear frame mount hole, possibly placing the motor right in the middle of the 6 and 8 cyl. stock positions. I'm not sure on this though. I am planning on using headers, but everything I've seen points to nothing being an exact fit except the Thorley's, but I want bigger primaries. Last edited by Jim_PA; 04-27-2010 at 11:17 AM. |
Clyde, any input on where the pol mounts put the engine? Do they use the rear 6 cyl frame holes?
Joe |
Ordered the POL mounts last wed, still havent seen them.
I ended up trying pontiac G8 manifolds. THEY WORK! You can use the stock 6 cyl pedestals in the stock location.
Joe |
1967 Chevy Short/Fleet 1969 Chevy Short/Step 2004.5 Dodge 2500 4x4 Cummins 6spd |
Truck and auto performance nut
yes...pics please.
I have the ECE mounts but am far from putting them in. my frame still doesn't even have a front crossmember yet. ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
I probably wont have any pics until saturday. I just moved so I am doing the swap at a friends house and won't get there until saturday.
Joe |
Joe |
#13 |
The POL mounts can put them in the forward or rearward mounting points, whichever you need. I tried stock mounts and after many swear words, I got them installed. However nothing would fit for exhaust manifolds, I tried stock truck, fbody and I also tried Sanderson shorties. When I put the POL mounts on it moved the motor up about 1" or so which made room for my Sanderson headers. I put them as far back as I could since I wanted dual electric fans with the stock radiator.
ECE I believe stradles both and puts the motor right in the middle of the mount holes.
#14 |
GM ONLY BABY!!!
Subscribing, LQ4 on the way for me. !!!!!!!!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
