Old 04-27-2010, 11:49 AM   #1
ubtripn
ubtripn's Avatar
Can a rubber bed mat cause rust like a plastic bedliner?
I have a rubber bed mat in my 68, has anybody ever had one of these cause any rust in the bed?
ubtripn is offline   Reply With Quote
Old 04-27-2010, 11:53 AM   #2
lks dcvn
lks dcvn's Avatar
Re: Can a rubber bed mat cause rust like a plastic bedliner?
yes - they can.
The lack of ventilation to allow the bed to dry completely creates the environment for surface rust and then it goes worse from there.
Try to keep the mat out of the bed and use it only when you need to haul something - that way you have the benefits of it, but reduce the negative aspects.
I do this with my trucks...
lks dcvn is offline   Reply With Quote
Old 04-27-2010, 11:59 AM   #3
cranetaker77
cranetaker77's Avatar
From what I have seen it does. My Dad has a Early Bronco, and he doesn't have carpet in it yet. So he had some rubber ford logo mats. I lifted one up one day and there was a whole lot of condensation under it. Granted his floor pans needed to be replaced anyways but, from seeing that condesation I'd say yes, that it is very possible.
1966 C-10 Stepside 355 CI
1994 Ford Lightning
1984 Ford Bronco II 302 V8
2007 Ford Ranger(Daily Driver)
cranetaker77 is offline   Reply With Quote
Old 04-27-2010, 12:23 PM   #4
Keith Seymore
Keith Seymore's Avatar
I haven't had rust issues, ever - but - my bed mat has little round "nubs" that space it up off the bed floor, and, in an '87, the bed floor has ribs which would also provide air flow.
The only thing would be were the bed mat abraids the paint off, leaving a bare spot, so you could have rust issues in a spot like that.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-27-2010, 12:30 PM   #5
tim21391
tim21391's Avatar
we had a 04 f150 had it for like 2 or 3 years we had a mat in it.. and when we went to trade it in all the clear coat was off which i assume was early stages of it deteriating.. or however you spell that word
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-27-2010, 12:53 PM   #6
ubtripn
ubtripn's Avatar
Wow - that is all good information, thanks!
Old 04-27-2010, 01:01 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
rust will get a better foothold if at any time air flow is reduced. period
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-27-2010, 02:58 PM   #8
barryvanhook
barryvanhook's Avatar
Smile Re: Can a rubber bed mat cause rust like a plastic bedliner?
For my last 4 trucks I've used a bed rug and experienced no rust problems whatsoever .... but then I live in Arizona, so YMMV.
Barry
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 04-27-2010, 07:49 PM   #9
ubtripn
ubtripn's Avatar
Sounds like it's not going to be worth using.
Old 04-27-2010, 08:04 PM   #10
A bed may will promote worse than a bedliner because it doesn`t stop water from getting under then traps it in.I know a wood bed will rot 10x faster with a bed mat.Any flaw in paint will get worse.
Old 04-27-2010, 08:15 PM   #11
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Do what I did...spray in bedliner...and then the rubber bed mat....clean low maintence...and ready to do business...
-Ron-
OldSkool71 is offline   Reply With Quote
Old 04-27-2010, 08:47 PM   #12
68gmsee
Active Member
68gmsee's Avatar
If your bed is good shape with no rust holes, pits, dents, etc., I'd try to keep it that way by not hauling stiff that would ruin it. If you need to use it to haul, then do what lks dcvn says and use a pad while you are hauling. Maybe even get a small utility trailer. These beds are getting harder to come by.
btw: I was going to spray mine but a friend told me not to do it. He's had trouble with the way his truck bed looks after 5 years in this hot Texas weather. And he says trying to remove it is a b-tch.
68gmsee is offline   Reply With Quote
Old 04-28-2010, 01:07 PM   #13
ubtripn
ubtripn's Avatar
I have been seriously considering rino-lining or something of the sort since I do want to use the truck as a truck. My one fear is getting it off if that becomes necessary. Can one spray a liner a second time in a few years if needed without removing the first layer?
