GMC 3Ton Custom Cab..
Hey everyone I found this truck while looking at an older Cadillac for sale. I took a look at this one and just wondering if it's worth $800. It's a Custom Cab, small back window, high floor hump with a 292 and a hoist. Also judging by the front signals being clear, I am thinking it is a 62' as well. There is a bit of rust on the rockers and the fenders are starting to rust in the usual places. The floors looked fairly solid.
I'm thinking of offering $300, but do you think it would be worth that? I was thinking of having it as a future project, after my 62' comes to an end. Maybe a car hauler with my extra Caddy500/T400? Thanks for the input! http://winnipeg.kijiji.ca/c-cars-veh...dIdZ195001373# My 62 as of now: ![]() |
1961 crewcab
Re: GMC 3Ton Custom Cab..
probably is a 62, I found a 62, it was the right vin code for a 62 had the clear signals and coil springs, but was titled as a 63....
if that is a 62 it will also have a torsion bar front end.... looks to be a good deal for 800, and a great deal for 300 if it was in my area I would buy it just for that outside mirror! ![]() gonna hazard a guess that it is not quite a 3 ton... I would say 1-1 1/2....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
That was my guess as well. The side emblems say 940 so that would be a 2 ton, would it not?
1961 crewcab
try http://www.6066gmcguy.org/ for some more gmc info, I do not know if he covers canadian trucks much.
also there is some info on the vin decoder page about canadian trucks, here: http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
The cab itself may be of a 940. You could have different payload ratings with the same badging, dictated by your axle rating. . According to my Canadian 65-74 medium duty truck parts book the first digit on the V.I.N. # indicates the year. Next letter would be Body style Next # should be 9 indicating GMC. next two digits is the series. next two digits are for the model. next digit would be # of cylinders. The remaining digits are the vehicule #.
Last letter is the GVW Rating. A 6000 or less B 6,001 to10,000 C 10,001 to 14,000 D 14,001 to 16,000 E 16,001 to 19,500 F 19,501 to 26,000 G 26,001 to 33,000 H 33,001 & Over The front Cab supports would have two threaded holes facing the back that the step support bracket would bolt to. I sold my 960 in the fall.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 04-27-2010 at 06:58 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm jumping on the 62 band wagon too. It has the earlier six cylinder rather than the 292 like the ad states. The engine would have been a 292 if it were a 63 model year truck.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would say it's a 1 ton. It's hard to say on the engine, I can't see enough of it to say for sure. That last pic of an engine is a completely different vehicle.
in the four pictures i see two different engines. one looks like a 235 or 261. the other engine pik is of a completley different truck & engine.
Definitely an earlier engine than 1963. Notice the road draft tube near the distributor and the round profile of the intake manifold rather than square.
UCA63
Screamin' deal on the caddy,nice score!
The 62,that fender looks very workable,the hood looks a little tweaked out,door doesn't look too bad,all the cc stuff appears to be there and if the p side is in the same shape I'd say 800 is a wee bit on the high side I see it's been listed for a week now. start at 300 he'll say 600(you know the routine) 450 would be as high as I would go either way looks like a good addition to your build T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Well I gave the guy an offer of $300 and he refused he told me he wants 800 firm. He still believes it's a 3ton. I'll give it a few weeks and then try again.. But for now I'll keep working on my own 62!
the 940 is a old school version of a 3500HD , the front wheels are 18 inch 5 lug , and the rear are 10 lug. I would go buy that right now if it wasn't so far away. the engine is probably a 261 maybe a 235 they look exactly the same from outside. I used to have the '72 version of that truck I hope my son doesn't see this
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
#13 |
It is a 1 1/4 ton model made between '60 and '62. In '63 this model was discontinued and replaced with a lighter duty 1 1/2 ton with large fenders and running boards. Canadian GMC 940 same as Chevy C 40. It looks like its easily worth $800 if not more. Remember that 11,000lb rear axle is geared even slower than the 7200lb C 30 1 ton rear end.
