04-27-2010, 02:41 PM | #1 |
Counter sunk
Anyone have a diagram or other information for drilling the bed wood and how to off set the relife for the off set washers. Thanks for any help here.Larry
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
04-27-2010, 03:36 PM | #2 |
Re: Counter sunk
04-27-2010, 11:02 PM | #3 |
Re: Counter sunk
Any one else?
04-27-2010, 11:13 PM | #4 |
Re: Counter sunk
Is this the one you're looking for? If so, PM me your address so I can send you a larger pic.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
04-27-2010, 11:42 PM | #5 |
Re: Counter sunk
A lot of good information regarding bed and wood installation can be found at Mar-k installation section in PFD format http://www.mar-k.com/installation_hints.html
As far as the offset washers try http://www.mar-k.com/mtgholes_3-8_ofst.pdf
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
04-29-2010, 05:48 PM | #6 | |
Re: Counter sunk
Now does anyone have this type of a picture like Dan posted for a short Step side . with locatins and hole sizes. Larry
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 Last edited by larry may; 04-29-2010 at 05:49 PM. |
04-30-2010, 09:54 PM | #7 |
Re: Counter sunk
Thank You all for the help . Got all the information down to a science now. Appreciate all your assistance. This 100% resto will be much better than last.
04-30-2010, 10:06 PM | #8 |
Re: Counter sunk
I could not find a 1 9/16 Forstner bit, but I did find an adjustable hole saw. I used the hole saw to cut a ring 1/8 deep and used a router with a 1/4 inch flat bit to slowly remove the rest of the wood. I set the depth the same as the thickness of the offset washer. Slowly works best, because if you slip, it's forever.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
