Old 04-27-2010, 04:46 PM   #1
qu1cks1lver56
qu1cks1lver56's Avatar
Dumping Exhaust Under Truck?
I recently put some new mufflers on my truck, and I'm happy with their sound but the passenger side tail pipe is at a downward angle now (previous exhaust was fully welded, I cut off old mufflers and clamped new ones on, passenger side was welded at a funny angle and now it's changed the tailpipe angle) so I've been thinking about cutting the tail pipes off right behind the mufflers and possibly putting turndowns on it, but I can't make up my mind. Someone wanna pitch in some ideas?
qu1cks1lver56 is offline   Reply With Quote
Old 04-27-2010, 04:50 PM   #2
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Re: Dumping Exhaust Under Truck?
I have mine dumped before the rear axle.
West Texas Z is offline   Reply With Quote
Old 04-27-2010, 04:51 PM   #3
Adams74Chevy
Adams74Chevy's Avatar
You could always dump them out the sides in front of the rear wheels.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 04-27-2010, 04:51 PM   #4
MotorHead Lon
MotorHead Lon's Avatar
Both my 90 and my 84 have the exhaust cut off at the muffler. The exhaust has a drone at hiway speeds but if a little noise doesnt bother you it isnt that bad. If you have a sliding back window you will get some exhaust in the cab if sitting at a red light.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 04-27-2010, 05:13 PM   #5
qu1cks1lver56
My plans eventually, but I'm looking for a quick fix right now lol.
And someone told me, since I have aluminum wheels, that having it exit in front of the tires will warp my aluminum wheels. Never heard that before but I wanna make sure before I do it.
Old 04-27-2010, 05:29 PM   #6
JW76
JW76's Avatar
if you can dump the exhaust out the side. I had turndowns under the truck and it sounded funny as the sound vibrated off the bottom of the truck and off the ground
JW76 is offline   Reply With Quote
Old 04-27-2010, 05:32 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
FWIW, I hate driving behind people with turndowns in a parking lot. They kick up dirt and gravel with their exhaust at low speeds.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-27-2010, 05:38 PM   #8
Prerunner1982
Prerunner1982's Avatar
I had mine dumped and it covered rear axle in blackness... perhaps the carb was a bit out of tune, but none the less.
Mine sounded great...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-27-2010, 05:51 PM   #9
fiddy9apache
fiddy9apache's Avatar
i prefure dumped exhaust, i hate tailpipes. i even dump quite mufflers.
fiddy9apache is offline   Reply With Quote
Old 04-27-2010, 05:51 PM   #10
3r!c84
Badass
3r!c84's Avatar
i have turn downs under my truck they sound good. yes they down put up some dust on a dirt road but its worth it
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 04-27-2010, 06:47 PM   #11
Alex1
Alex1's Avatar
Warp the rims LOL - yeah, I don't think so.
Alex1 is offline   Reply With Quote
Old 04-27-2010, 07:53 PM   #12
SCOTI
SCOTI's Avatar
I prefer full length tailpipes that are 'well placed'.
The noise level w/dumped exhaust is much worse in the cab (especially on older trucks that don't have the interior insulation/plastics to help isolate exterior sounds. I drove board member 'Jonboy's' truck back to his house after dropping it last weekend. We were forced to cut off the tail pipes of his newly installed 2.5" dual Flowmaster exhaust because the kick-up over the rearend housing was hitting solid. The truck was much louder & even on that short 20min drive, it got 'old' real fast..... As mentioned, it also kicks up a lot of dust/debris from the ground (if the truck is low enough) which can make the underside a mess as well as anything behind you (something to remember @ local cruises/car shows).
I've always preferred the quiet vehicle that hauls arse vs. the loudest thing in the parking lot that's a stock motor w/dumped exhaust.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2010, 09:13 PM   #13
qu1cks1lver56
lol well I didn't wanna chance it, I can't afford new ones atm.
I cut it off about 6 inches behind the mufflers, ~8-10 inches in front of the rear end. It doesn't sound bad, but it lost a lot of the rasp it had to it with full tail pipes and its REAL bassy @ idle. Not sure how I like it, gonna try some turndowns and see how I like that.
Old 04-28-2010, 04:43 PM   #14
68Timber
I know the pieces fit
68Timber's Avatar
It will ruin the finish of an aluminum wheel if you're running cats.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-28-2010, 05:05 PM   #15
Mayhem.Evol
Ive driven a friend's truck w/ the turn downs right after the muffler, it was a newer gmc (like 03).. but its a z71 so it sits up higher than these trucks.. i think it sounds kool and it does drone at constant speeds but it never gets annoying
Mayhem.Evol is offline   Reply With Quote
Old 04-28-2010, 05:37 PM   #16
qu1cks1lver56
What about with no cats? Am I safe?
Old 04-28-2010, 06:59 PM   #17
tdiffee
tdiffee's Avatar
First it won't hurt your rims it won't be that close.
Second I have run turn downs on 5 different vehicles and 3 of them were Tahoes. With a good muffler (50 series flow or magnaflow) cab noise is not that bad. I just installed a new cat and a magnaflow single in and dual out with 2 1/4" turndowns and I love the way it sounds but I don't like a loud exhaust. Mine rumbles at an idle and when it is going down the road it is not bad at all but it dumps right before my rear end and the turn downs are 30 degrees. there is my .02
87 Short Wide 305 TBI 700R4
86 Honda 350x (Resto Project Almost Complete)
07 Trailblazer SS (My Wife's Grocery Getter)
94 Camaro Z28
tdiffee is offline   Reply With Quote
Old 04-28-2010, 07:03 PM   #18
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ya x2 I have never heard that before either! I like headers with exhaust I have had full exhaust come out behind the tires. I also have glasspacks with turn downs that are under the truck and they sound awesome a lil loud when I am on it though
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-28-2010, 07:44 PM   #19
qu1cks1lver56
Haha thanks guys, put some turndowns on today, im still not completely happy, still think I want it out in front of the tires.
Old 04-28-2010, 07:44 PM   #20
Edgel82c10
Edgel82c10's Avatar
Mines dumped right behind mufflers 3inch inlet and outlet.
Edgel82c10 is offline   Reply With Quote
Old 04-28-2010, 09:33 PM   #21
3r!c84
Badass
3r!c84's Avatar
what kind of mufflers?
-00 Saturn 5spd
1/4:13:90
Old 04-29-2010, 08:43 AM   #22
Edgel82c10
Edgel82c10's Avatar
Flowmasters not sure which ones they were put on truck 10yrs ago it had been parked until 2 months ago when i started my rework on it.
Old 04-29-2010, 10:13 AM   #23
68Timber
68Timber's Avatar
Yep.
John
74 Honda Z50 build
Old 04-29-2010, 02:11 PM   #24
tucsonjwt
My duals are dumped behind the rear axle and out the side. I added stainless turn downs to keep the exhaust carbon off the fenders. I have a dump box, so my exhaust must exit well short of the rear bumper, or the exhaust tips will be knocked off when the box is in the full up position.
tucsonjwt is offline   Reply With Quote
Old 04-29-2010, 02:16 PM   #25
tucsonjwt
